:clap:Quote:
Originally Posted by Tyrou
but I think I already said this :D
:clap:Quote:
:D :toast:Quote:
P4M 1.8 out of a Dell, bought off Ebay for $60. This CPU will do 340fsb on phase and 311 aircooled. On the P4C800E 1.5Vcore gets you 300+ on the DFI I had to set 1.6 to match it but its still impressive.
302air cooled full stable.
http://homepage.ntlworld.com/ad.leac...arty/cpuz1.JPG
You don't seem to know GF6600GT stock clock is 500MHz? :confused:Quote:
Originally Posted by fareastgq
300MHz is just the idle freq the card runs 2D...
http://valid.x86-secret.com/show_oc.php?id=42418
Intel Pentium 4 / 506 / 2660 MHz @ 5326 MHz
Hehe, was just thinking that makes you a member of both the -100C and +100% clubs, grats :toast:Quote:
He became a -100c club member longtime before the +100% one :DQuote:
Originally Posted by LowRun
What about a 100% FSB overclock ?
Ryan
AFAIK anyone with a half decent dfi nf4 board would easily do that. (unless were talking ram too)Quote:
Originally Posted by Banzai
Yeah easy to do, 560 is the record, for now... :rolleyes:Quote:
Originally Posted by Vincentvega18
I overclocked my duron 1400 100%. Guess I belong to this club too...only thing is, I gave it away to lit'ol ones.
Of course i knew that ;)Quote:
Originally Posted by Shinuza
Here's mineQuote:
440BX @ 200MHz
Here's mine..oldschool XP-M Powerrrrr! :D
Watercooled....kinda killed it with 2.2v :lol2:
http://www.xtremesystems.org/forums/...1&d=1133900914
FSB is too easy...
can i join the 100% club too ?
opty 144 1.8Ghz@3637Mhz (soon better...)
http://valid.x86-secret.com/show_oc.php?id=57577
http://valid.x86-secret.com/cache/57577.png
dammit im Close 90% with a venice 3.0+ and without hard optimized [1 stick ram ., pci card , no usb devices :hehe: ] i think if i switch from single stage 2 dryice or cascade i can make it . :banana:
esdee ? esdee ? :cheer2:
I have a new one 100% oc on air :P because it seems theres alotta dam ppl here with 100% oc's these days, and aparently some in the good ol days as well..
Love the 1700XP would like to see a 4Ghz XP2600M 100% now thatd be impressive, but impossible..
So this thread still lives :)
I've bumped my previous result with an Celeron Mobile 1400 to this.
175.6% overclock
http://www.nordichardware.se/smpc200...1134843980.jpg
awesome
I' ll never be able to catch you , even if i can put my 1.8 under LN2
:slobber: Go on bro :slapass:Quote:
Originally Posted by flo850
O_o Did you take the top of your sempron 2500+ off to get a speed like that? Eather my Die sucks or it has something to do with the CPU die and the case on the CPU itself that limits the OC for some reason. Tho that sounds silly. PPL are getting much better OC's it seems by taking off the metal top of the CPU or something.Quote:
Originally Posted by HydroX
well.. most of Sempron 2500+ has bad Integrated Mem Controller, so it can run high, and mostly maxed at 340-360 MHz. And I was lucky, got this cpu, which can run 380 MHz daily and after removing the IHS (this is the thing you called "metal top of the CPU"), I can run at 402 MHz for screenie with plain watercooling
So you took it off with a razor blade. The IHS off really makes a diff. I wonder why? O_o Well it sounds like its worth taking off to get afew 100+ more MHz out of it. I don't use the normal heatsink. Its a masscool heatsink for this one. Wonder if I'll need to mod the heatsink stand and lower it so the heatsink and cpu come into contact? Wonder why the IHS is so big of a deal to get 30fsb more out of it when its just a peice of metal covering the CPU top. Hmm... quite intresting.Quote:
