Same pw as earlier, see post #91
Just released for the 990FX Extreme9, enjoy. :)
P1.40 final
ASRock > 990FX Extreme9 BIOS
L1.30B betaQuote:
1. Change Internet Flash server.
2. Improve memory compatibility.
3. Update UEFI RAID driver.
4. Support AMD3+ FD9590FHW8KHK and FD9370FHW8KHK CPU.
ASRock > 990FX Extreme9 beta
New firmware ( 1.40 ) for Asrock Extreme 9 at Asrock website.
http://www.asrock.com/mb/AMD/990FX%2...wnload&os=BIOS
Support for new Vishera processors.
can you please add switches for every option so we can run it silently at system startup and after its done to close itself...
This cpu hack does wonders for my Asrock setup in sig. Thanks for taking the time to do this!
Just found my FX-8150 that earlier managed SP1M at 10.95s. It will be interesting to see what is possible with this fix, LN2 and better memory modules. :)
Thanks Stilt! You're the king! (and have been for many years in my opinion)
why can't i disable NRAC blocking on my Zambezi?
the fix is only for vishera not zambezi chips.
The Stilt - very, very much interesting find! Thank you very much for it, amazing work. Finally we getting closer to understand the SuperPi lack of speed on modern AMD CPU's. But I do have a question - it is possible to detect, witch CPU's have this disabled NRACK block?
And will be possible to re-enable it for other AMD CPU's like the Zambezi line, for example?
I believe it would be a very interesting patch for many users then... :)
http://rog.asus.com/forum/showthread...untry=&status=
AMD WR 32M and thx to Stilt in article :)
Stilt: what about NRAC blocking at Steamroller B? Or they (AMD) fixed it now?
