Originally Posted by
Koolance
Hey Stren,
I think you have a faulty block from us (warped or otherwise not flat), so we'll ship out another one. You mentioned a less than desirable paste spread. Do the standoffs sit flush when placed onto a flat surface, or does the block rock a little? In our tests on both Titan and GTX 780, the GPU was noticeably cooler with VID-NXTTN than with EK's. This "should" be expected since we're using denser and thinner fins, so I think this certainly sounds like a contact issue.
A little off-topic, but our Titan block will be the first to use our new upcoming acetal SLI bridge connectors (as opposed to our usual sliding pipes). That's the reason the fitting area can be removed from the main block and has its own o-ring seal.
Tim
