All sorts of projects..
http://img651.imageshack.us/img651/3534/1wcgt.jpg
I need to be up in 4 hours, Maybe one of the others can put together a complete all projects app_info from the ones we have here for you (we normally don't need it because we haven't enough cores) :)
ok MM ...
1. Change your WCG profile to only run hcc and hcc gpu
2. Abort all of the other unstarted non-hcc cpu tasks
3. While we wait for the non-hcc cpu tasks to finish out we'll get some basics in place
4. Make a folder somewhere not in the BOINC structure
5. Copy the following files into the new folder from \BOINC\projects\www.worldcommunitygrid.org
5a. hcckernel.cl.6.56
5b. wcg_hcc1_img_6.56_windows_intelx86__ati_hcc1
5c. wcg_hcc1_img_6.56_windows_intelx86
6. In the new folder make a file named app_info.xml
6a. Make the file with notepad but make sure to change the file type to "All Files" when you save
7. copy the following into the app_info file
Code:<app_info>
<app>
<name>hcc1</name>
<user_friendly_name>XtremeSystems Crunches Cancer</user_friendly_name>
</app>
<file_info>
<name>wcg_hcc1_img_6.56_windows_intelx86</name>
<executable/>
</file_info>
<file_info>
<name>wcg_hcc1_img_6.56_windows_intelx86__ati_hcc1</name>
<executable/>
</file_info>
<file_info>
<name>hcckernel.cl.6.56</name>
<executable/>
</file_info>
<app_version>
<app_name>hcc1</app_name>
<version_num>656</version_num>
<platform>windows_intelx86</platform>
<avg_ncpus>1.000000</avg_ncpus>
<max_ncpus>1.000000</max_ncpus>
<flops>3231932486.733310</flops>
<api_version>6.13.0</api_version>
<file_ref>
<file_name>wcg_hcc1_img_6.56_windows_intelx86</file_name>
<main_program/>
</file_ref>
</app_version>
<app_version>
<plan_class>ati_hcc1</plan_class>
<coproc>
<type>ATI</type>
<count>0.500000</count>
</coproc>
<file_ref>
<file_name>wcg_hcc1_img_6.56_windows_intelx86__ati_hcc1</file_name>
<main_program/>
</file_ref>
<file_ref>
<file_name>hcckernel.cl.6.56</file_name>
<open_name>hcckernel.cl</open_name>
</file_ref>
</app_version>
</app_info>
We'll pick up again once the old non-hcc cpu tasks finish up.
Please post back with the name of the new folder you created so I can use its real name for you.
8. Once the non-hcc cpu tasks are finished, uploaded, and reported - fully stop boinc.
9. Copy the app_info.xml file into the worldcommunitygrid.org folder
10. Verify that the files from step 5 still exist in the worldcommunitygrig.org folder
10a. If they are missing you can copy them from the *new* folder into worldcommunitygrid.org
11. Restart BOINC.
12. If you have any issues please post up the messages from the event log.
"We'll pick up again once the old non-hcc cpu tasks finish up"
No, give me the rest! :D
see above :)
OK I've had absolutely no hangs since the driver change to 12.11b4 so we're good there.
However, I keep having the client randomly start processing some HCC units on the CPU, get a unit (or two, or three) about halfway done, then essentially abandon it to run 8 GPU threads again and it just lets the half-run unit expire. Any ideas what is up with that?
Sparky,
Have you by chance selected the: " If there is no work available for my computer for the projects I have selected above, please send me work from another project." option in the profile for that particular device.
Cheers,
Jean-Guy
No I haven't. What gets me is they are all HCC units, including the ones that started on the CPU. I'm just not sure what is triggering it to start them on the CPU in the first place, just to essentially abandon them halfway through later :confused:
Are you are using an app_info that has both hcc_cpu and gcc_gpu and it is configured to run 8 GPU WUs at the same time? That would cause this issue as it is asking for cpu WUs but has no good way to actually run them so I'm guessing they only run when they hit high priority or your GPU cache runs low, or if you are manually suspending some GPU WUs to try and get them to not all be sync'd. I would switch to using an hcc_gpu only app_info. Don't forget to set NNT, abort all CPU WUs, stop BOINC fix your app_info and then restart.
This app_info.xml GPU only file is getting 86 results an hour (2128 results and 482,698 points total for yesterday only) from my FX-8150 and dual HD-6990's rig:
Two threads per GPU for a total of eight, one per each CPU core.
<app_info>
<app>
<name>hcc1</name>
<user_friendly_name>Help Conquer Cancer</user_friendly_name>
</app>
<file_info>
<name>wcg_hcc1_img_6.56_windows_intelx86__ati_hcc1 </name>
<executable/>
</file_info>
<file_info>
<executable/>
</file_info>
<app_version>
<avg_ncpus>1.0</avg_ncpus>
<max_ncpus>1.0</max_ncpus>
<coproc>
<type>ATI</type>
<count>.5</count>
</coproc>
<file_ref>
<file_name>wcg_hcc1_img_6.56_windows_intelx86__ati _hcc1</file_name>
<main_program/>
</file_ref>
<file_ref>
</file_ref>
</app_version>
</app_info>
Here is my app_info I pulled from another thread. Looking at it I'm thinking it is a CPU+GPU :doh:
So this is what it would have to look like for GPU only?Code:<app_info>
<app>
<name>hcc1</name>
</app>
<file_info>
<executable/>
</file_info>
<file_info>
<executable/>
</file_info>
<file_info>
<executable/>
</file_info>
<app_version>
<coproc>
<type>ATI</type>
<count>.125</count>
</coproc>
<file_ref>
<main_program/>
</file_ref>
<file_ref>
</file_ref>
</app_version>
<app_version>
<file_ref>
<main_program/>
</file_ref>
</app_version>
</app_info>
Code:<app_info>
<app>
<name>hcc1</name>
</app>
<file_info>
<executable/>
</file_info>
<file_info>
<executable/>
</file_info>
<app_version>
<coproc>
<type>ATI</type>
<count>.125</count>
</coproc>
<file_ref>
<main_program/>
</file_ref>
<file_ref>
</file_ref>
</app_version>
</app_info>
Trying to build a master file from all the posts on this so far here before I get a shower and go to work. If anyone has time on their hands and would like to proof read for duplication etc. it sure would help. No HFCC so far.
Code:<app_info>
<app>
<name>hcc1</name>
</app>
<file_info>
<name>wcg_hcc1_img_7.05_windows_intelx86__ati_hcc1</name>
<executable/>
</file_info>
<file_info>
<name>hcckernel.cl.7.05</name>
<executable/>
</file_info>
<app_version>
<version_num>705</version_num>
<coproc>
<type>ATI</type>
<count>.5</count>
</coproc>
<file_ref>
<file_name>wcg_hcc1_img_7.05_windows_intelx86__ati_hcc1</file_name>
<main_program/>
</file_ref>
<file_ref>
<file_name>hcckernel.cl.7.05</file_name>
</file_ref>
</app_version>
______________________________________________________________________________
<app>
<name>gfam</name>
<user_friendly_name>GO Fight Against Malaria</user_friendly_name>
</app>
<file_info>
<name>wcgrid_gfam_vina_6.12_windows_x86_64</name>
<executable/>
</file_info>
<file_info>
<name>wcgrid_gfam_vina_prod_x86_64.exe.6.12</name>
<executable/>
</file_info>
<file_info>
<name>wcgrid_gfam_gfx_prod_x86_64.exe.6.12</name>
<executable/>
</file_info>
<app_version>
<app_name>gfam</app_name>
<version_num>612</version_num>
<platform>windows_x86_64</platform>
<flops>3347548492.458962</flops>
<api_version>7.1.0</api_version>
<file_ref>
<file_name>wcgrid_gfam_vina_6.12_windows_x86_64</file_name>
<main_program/>
</file_ref>
<file_ref>
<file_name>wcgrid_gfam_vina_prod_x86_64.exe.6.12</file_name>
<open_name>AutoDockVina64.exe</open_name>
</file_ref>
<file_ref>
<file_name>wcgrid_gfam_gfx_prod_x86_64.exe.6.12</file_name>
<open_name>graphics_app</open_name>
</file_ref>
</app_version>
<app_version>
<file_ref>
<main_program/>
</file_ref>
<file_ref>
</file_ref>
<file_ref>
</file_ref>
</app_version>
<app>
<name>sn2s</name>
<user_friendly_name>Say No to Schistosoma</user_friendly_name>
</app>
<file_info>
<name>wcgrid_sn2s_vina_6.20_windows_x86_64</name>
<executable/>
</file_info>
<file_info>
<name>wcgrid_sn2s_vina_prod_x86_64.exe.6.20</name>
<executable/>
</file_info>
<file_info>
<name>wcgrid_sn2s_gfx_prod_x86_64.exe.6.20</name>
<executable/>
</file_info>
<app_version>
<app_name>sn2s</app_name>
<version_num>620</version_num>
<file_ref>
<file_name>wcgrid_sn2s_vina_6.20_windows_x86_64</file_name>
<main_program/>
</file_ref>
<file_ref>
<file_name>wcgrid_sn2s_vina_prod_x86_64.exe.6.20</file_name>
</file_ref>
<file_ref>
<file_name>wcgrid_sn2s_gfx_prod_x86_64.exe.6.20</file_name>
</file_ref>
</app_version>
<app_version>
<file_ref>
<main_program/>
</file_ref>
<file_ref>
</file_ref>
<file_ref>
</file_ref>
</app_version>
_______________________________________________________________________________
<app>
<name>cep2</name>
<user_friendly_name>The Clean Energy Project - Phase 2</user_friendly_name>
</app>
<file_info>
<name>wcgrid_cep2_6.40_windows_intelx86</name>
<executable/>
</file_info>
<file_info>
<name>wcgrid_cep2_qchem_6.40_windows_intelx86</name>
<executable/>
</file_info>
<file_info>
<name>wcgrid_cep2_graphics_6.40_windows_intelx86</name>
<executable/>
</file_info>
<file_info>
<name>cep2_qcaux_6.40.zip</name>
</file_info>
<file_info>
<name>cep2_images_6.40.zip</name>
</file_info>
<app_version>
<app_name>cep2</app_name>
<version_num>640</version_num>
<flops>1982909446.217418</flops>
<api_version>6.11.7</api_version>
<file_ref>
<file_name>wcgrid_cep2_6.40_windows_intelx86</file_name>
<main_program/>
</file_ref>
<file_ref>
<file_name>wcgrid_cep2_qchem_6.40_windows_intelx86</file_name>
<open_name>wcgrid_cep2_qchem_prod_linux.x86</open_name>
</file_ref>
<file_ref>
<file_name>wcgrid_cep2_graphics_6.40_windows_intelx86</file_name>
</file_ref>
<file_ref>
<file_name>cep2_images_6.40.zip</file_name>
<open_name>Cep2_images.zip</open_name>
</file_ref>
<file_ref>
<file_name>cep2_qcaux_6.40.zip</file_name>
<open_name>qcaux2.zip</open_name>
</file_ref>
</app_version>
<app>
<name>faah</name>
<user_friendly_name>FightAIDS@Home</user_friendly_name>
</app>
<file_info>
<name>wcg_faah_autodock_6.40_windows_intelx86</name>
<executable/>
</file_info>
<file_info>
<name>wcg_faah_autodock_graphics_6.40_windows_intelx86</name>
<executable/>
</file_info>
<file_info>
<name>faah_protease_6.40.dat</name>
</file_info>
<file_info>
<name>faah_image_6.40.tga</name>
</file_info>
<app_version>
<app_name>faah</app_name>
<flops>3894434573.022523</flops>
<api_version>6.3.3</api_version>
<file_ref>
<file_name>wcg_faah_autodock_6.40_windows_intelx86</file_name>
<main_program/>
</file_ref>
<file_ref>
<file_name>wcg_faah_autodock_graphics_6.40_windows_intelx86</file_name>
</file_ref>
<file_ref>
<file_name>faah_protease_6.40.dat</file_name>
<open_name>protease.dat</open_name>
</file_ref>
<file_ref>
<file_name>faah_image_6.40.tga</file_name>
<open_name>wc_grid_s1b2.tga</open_name>
</file_ref>
</app_version>
<app>
<name>hpf2</name>
<user_friendly_name>Human Proteome Folding - Phase 2</user_friendly_name>
</app>
<file_info>
<name>wcg_hpf2_rosetta_6.40_windows_intelx86</name>
<executable/>
</file_info>
<file_info>
<name>wcg_hpf2_6.40.tga</name>
<executable/>
</file_info>
<file_info>
<name>wcg_hpf2_rosetta_graphics_6.40_windows_intelx86</name>
<executable/>
</file_info>
<file_info>
<name>hpf2_6.40_win_paths.txt</name>
<executable/>
</file_info>
<app_version>
<app_name>hpf2</app_name>
<flops>3570131549.238372</flops>
<file_ref>
<file_name>wcg_hpf2_rosetta_6.40_windows_intelx86</file_name>
<main_program/>
</file_ref>
<file_ref>
<file_name>wcg_hpf2_6.40.tga</file_name>
<open_name>wc_grid_hpf2.tga</open_name>
</file_ref>
<file_ref>
<file_name>wcg_hpf2_rosetta_graphics_6.40_windows_intelx86</file_name>
</file_ref>
<file_ref>
<file_name>hpf2_6.40_win_paths.txt</file_name>
<open_name>paths.txt</open_name>
</file_ref>
</app_version>
<app_version>
<file_ref>
<main_program/>
</file_ref>
<file_ref>
</file_ref>
<file_ref>
</file_ref>
<file_ref>
</file_ref>
</app_version>
_________________________________________________________________________________
Drug Search for Leishmaniasis
__________________________________________________________________________________
Help Cure Muscular Dystrophy - Phase 2
___________________________________________________________________________________
Help Fight Childhood Cancer
_________________________________________________________________________________________
<app>
<name>hcc1</name>
</app>
<app_version>
<file_ref>
<main_program/>
</file_ref>
</app_version>
</app_info>
I started running out also and had just finished switching my rigs around when they started showing up again ... all reset back to optimal gpu crunching :sigh:
I'm letting my current log of CPU units work through then switching it over to full GPU again. Means my PPD will be down in the tank for a little while however. I just don't really want to abort several dozen units.
Hey guys I need some help here, can't get any WU's to my 6990+6970(in the same rig):yawn:
I'm using this in my APP_INFO:XML
But I get no WU's and this in the logPHP Code:<app_info>
<app>
<name>hcc1</name>
</app>
<file_info>
<executable/>
</file_info>
<file_info>
<executable/>
</file_info>
<app_version>
<coproc>
<type>ATI</type>
<count>.166</count>
</coproc>
<file_ref>
<main_program/>
</file_ref>
<file_ref>
</file_ref>
</app_version>
</app_info>
The app_info works on two other rigs, could it be that this is an SR-2?PHP Code:05/11/2012 22:47:30 | | Starting BOINC client version 7.0.28 for windows_x86_64
05/11/2012 22:47:30 | | log flags: file_xfer, sched_ops, task
05/11/2012 22:47:30 | | Libraries: libcurl/7.25.0 OpenSSL/1.0.1 zlib/1.2.6
05/11/2012 22:47:30 | | Data directory: C:\ProgramData\BOINC
05/11/2012 22:47:30 | | Running under account Cruncher1
05/11/2012 22:47:30 | | Processor: 24 GenuineIntel Intel(R) Xeon(R) CPU X5670 @ 2.93GHz [Family 6 Model 44 Stepping 2]
05/11/2012 22:47:30 | | Processor: 256.00 KB cache
05/11/2012 22:47:30 | | Processor features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss htt tm pni ssse3 cx16 sse4_1 sse4_2 syscall nx lm vmx smx tm2 dca popcnt aes pbe
05/11/2012 22:47:30 | | OS: Microsoft Windows 7: Ultimate x64 Edition, Service Pack 1, (06.01.7601.00)
05/11/2012 22:47:30 | | Memory: 11.99 GB physical, 23.98 GB virtual
05/11/2012 22:47:30 | | Disk: 195.21 GB total, 94.82 GB free
05/11/2012 22:47:30 | | Local time is UTC +1 hours
05/11/2012 22:47:30 | | ATI GPU 0: Cayman (CAL version 1.4.1741, 2048MB, 2016MB available, 6374 GFLOPS peak)
05/11/2012 22:47:30 | | ATI GPU 1: Cayman (CAL version 1.4.1741, 2048MB, 2016MB available, 6374 GFLOPS peak)
05/11/2012 22:47:30 | | ATI GPU 2: Cayman (CAL version 1.4.1741, 2048MB, 2016MB available, 6374 GFLOPS peak)
05/11/2012 22:47:30 | | OpenCL: ATI GPU 0: Cayman (driver version 1016.4 (VM), device version OpenCL 1.2 AMD-APP (1016.4), 2048MB, 2016MB available)
05/11/2012 22:47:30 | | OpenCL: ATI GPU 1: Cayman (driver version 1016.4 (VM), device version OpenCL 1.2 AMD-APP (1016.4), 2048MB, 2016MB available)
05/11/2012 22:47:30 | | OpenCL: ATI GPU 2: Cayman (driver version 1016.4 (VM), device version OpenCL 1.2 AMD-APP (1016.4), 2048MB, 2016MB available)
05/11/2012 22:47:30 | World Community Grid | Found app_info.xml; using anonymous platform
05/11/2012 22:47:30 | World Community Grid | File referenced in app_info.xml does not exist: wcg_hcc1_img_6.56_windows_intelx86__ati_hcc1
05/11/2012 22:47:30 | World Community Grid | File referenced in app_info.xml does not exist: hcckernel.cl.6.56
05/11/2012 22:47:30 | World Community Grid | [error] State file error: missing application file wcg_hcc1_img_6.56_windows_intelx86__ati_hcc1
05/11/2012 22:47:30 | | Config: report completed tasks immediately
05/11/2012 22:47:30 | | Config: use all coprocessors
05/11/2012 22:47:30 | | Config: GUI RPC allowed from:
05/11/2012 22:47:30 | | Config: 192.168.0.111
05/11/2012 22:47:30 | World Community Grid | URL http://www.worldcommunitygrid.org/; Computer ID 2168370; resource share 100
05/11/2012 22:47:30 | World Community Grid | General prefs: from World Community Grid (last modified 17-Oct-2012 01:18:55)
05/11/2012 22:47:30 | World Community Grid | Computer location: home
05/11/2012 22:47:30 | | General prefs: using separate prefs for home
05/11/2012 22:47:30 | | Reading preferences override file
05/11/2012 22:47:30 | | Preferences:
05/11/2012 22:47:30 | | max memory usage when active: 12279.18MB
05/11/2012 22:47:30 | | max memory usage when idle: 12279.18MB
05/11/2012 22:47:30 | | max disk usage: 50.00GB
05/11/2012 22:47:30 | | max download rate: 9999002 bytes/sec
05/11/2012 22:47:30 | | max upload rate: 999004 bytes/sec
05/11/2012 22:47:30 | | (to change preferences, visit the web site of an attached project, or select Preferences in the Manager)
05/11/2012 22:47:30 | | Not using a proxy
The problem is that you don't have the necessary executable files
so what you can do it fully stop BOINC, remove the app_info (I just rename it to __app_info.xml) and restart BOINC. Once you have some tasks downloaded and running fully stop BOINC again, put the app_info file back in place and restart. I like to keep copies of the executables in a separte folder also so I can easily restore them if necessary.
I would try 8 if not only to try and increase production but also to just to see the sheer awesomeness of an SR2 shine!!!
