I think,because upcoming Z77. :D
thanks LardArse for the advice will get to it right away , board seems stable as hell the with all memory secondary timing tight as can be . .
very strong in memory dept
I need more work getting stable at 2000c8 with the hypers, so I decided to go up on the cpu multi.
4.7 seems to be running ok, a short blend run.
http://i43.tinypic.com/2yvs2nr.jpg
Ordered my Rampage IV Extreme :)
Im using default blend at the moment, have 3400mb of free memory available out of 8gb. Im not going for 24/7 stability on this oc, but this is IMO the best way to learn a new setup. Then off to benching.
got my R4E up and running
just getting everything reloaded now
http://img225.imageshack.us/img225/4787/r4e1.jpg
had it lose it's boot drive a (two ssd raid) till i unplug a usb memory card reader with a compact flash card in it then it booted fine :shrug:
i'm on 0076b bios
Thats a smoking setup, love that nicotine setup.
Too bad the board does not match but just need to wait after the next 100packs it will blend just fine...
Nice build bill_d :up:
Went up 100mhz, set memory to custom to stress more.
http://i39.tinypic.com/rjpemg.jpg
Not the fastest time, a crappy w7 install but it did complete the test :D
http://i42.tinypic.com/ambiqe.jpg
Ok, so updated( I think) the BIOS to 0802 using the EZ Flash utility. It all appeared to go well. The bios was updated and the system restarted a couple of times. Then I get to the Amibios screen and I can't get beyond it. It reads the bios as 0802 but tells me at the bottom to enter set up to recover bios setting. It says to press F1 to enter setup, but F1 has no effect. Hopefully I'm missing the obvious here?
Forgot to add, I now have the P9X79 Deluxe with the 3930K and a 32gb Gskill kit.
Can someone help me out with a suggestion?
Thanks!
What's with the 3:30 plus minutes sitting on a code of 99 during post? The board and processor seemed fine a couple of days on bios 0604--then I moved up to 075b and then 076b. With a few crashes now the machine posts holding at code 99 forabout 3 and a half minutes and then completes normally--is the board gone bad or the processor? why such a long time and why such an extended post process and time? Thanks for any help
Any ideas how much a 3960x 5Ghz with 1.41v would worth ?
Updated first post:
AIDA 64 stress test (with AVX) and simultaneous Unigine loops run by JJ on all boards at 4.8GHz CPU with 32GB of memory:
P9X79 Pro:
http://img141.imageshack.us/img141/8...1600ddr332.jpg
Uploaded with ImageShack.us
P9X79 Deluxe:
http://img141.imageshack.us/img141/2...ghz1600ddr.jpg
P9X79 WS:
http://img534.imageshack.us/img534/1...600ddr332g.jpg
Sabertooth X79:
http://img406.imageshack.us/img406/3...48ghz1600d.jpg
Rampage IV Extreme:
http://img15.imageshack.us/img15/820...eme48ghz16.jpg
Thanks a lot! I am trying the BIOS Flashback. Is there any idea how long it takes? The Flashback button has been illuminated for 10 minutes or so. Will that light turn off when it is done?
I was looking for a 'BIOS update light' near the bios chip like on the ROG boards, but I didn't see one.
Thanks for the help.
http://img263.imageshack.us/img263/2...e032medium.jpg
[Update]This the screen I get stuck on. It shows the updated bios, but will not move beyond this screen. I have cleared cmos several times, to no avail. I know the keyboard works because I can restart from here with a ctrl/alt/dlt.
USB BIOS flashback has not worked, The light will come on, but will n ever turn off(up to an hour).
Did I brick the board?
If you can still to the screen you show above, sse only one memory module and see if you can make it into UEFI. BIOS flashback should only take a few minutes so something is amiss.
-Raja
Thanks for the tips Raja. There is no change with one dimm populated other than the screen I showed above does recognize 4 gb now. I really do appreciate the help.
It is strange, because it's not as if the keyboard is not working because I can reboot with it on that screen, but pushing F1 does nothing.
Any other suggestions?
Roger. Will do, thanks for the effort.
A g19 keyboard and mouse from logitech, a dell 3007hpc monitor with ports/slots (in the slot a lexar 4gb card, in the ports a headset charger without headset attached so it would come up as nothing and a microsoft sensor for a gamepad), 2 r5000hd video dvrs, a HTC phone, an ipod jack but without a device attached to boot, a canon printer. I suspect it is the r5000 dvrs that are causing the problem on an Asus Maximus 4 extreme and extreme Z that I previously used after I would hook up the dvrs the motherboard would show "no keyboard error' on next boot and I would have to attach an old fashion ps2 plug keyboard in to be able to make selections before post completes or after post to select different operating systems to run--steve
