Agree with this 100%. Thought I'd give them a shot but their bios's aren't really well done and they take forever, I'll stick with Asus and MSI and I'm pawing this board off asap.
Check your ram timing entry and use the default jedec timing, try cl8 or cl9 for 1866, 990fx don't support 2133 unless you OC it from there. I think the problem is the compatibility of your ram modules.Quote:
When I tried to have a look what the BIOS had changed the timings to after reverting to DDR-800 MHz I was met by this error:
You have entered an invalid value in ram timing that's why it prompts you for an error. try using the default timing as I've said.
goodluck...:)
PS
I've emailed ASROCk for the last 7 days and they didn't replied to me yet, I've got problems configuring my ripjaws ddr3 1600 @ cl6 timing, and also requested them to include mem multiplier options in the uefi. Hoping they would reply to me...
The only problem being encountered here is the ram configurations and everything can be run on default settings. I think it can be corrected by a bios update hopefully, other than that this board has a lot of features it performs and OC so well not only on par with ASUS\GIGA but even more...:yepp:Quote:
My ddr3 1600 is running @ ddr3 1698 cl8 so far so good, I'll check if i can raise it up a bit...:)
max oc for my 955be:
http://i456.photobucket.com/albums/q...l/95545ghz.jpg
If you take a look at the pictures I've provided and the text I've written you'll see that the board fails to do my Mushkins at 1866 Mhz CL9. Even with the CPU on stock. Here are the pictures of this again:
http://i44.tinypic.com/2j5b3mw.jpg
As you can see I'm trying for 1866 MHz at 9-11-10-28-28, this works until I decide to turn off the computer and turn it on again and this is what happens when I did:
http://i40.tinypic.com/280uusw.jpg
I have also tried different RAM. Here are pictures with a pair of 2GB 1600 MHz CL9 (9-9-9-24) Corsair XMS3:
http://i1139.photobucket.com/albums/...reshutdown.png
Better picture: http://imageshack.us/f/685/beforeshutdown.png
And as you can see they work fine until I decide to turn it off and on again:
http://i1139.photobucket.com/albums/...lackscreen.png
Better picture: http://imageshack.us/f/18/aftershutdownandblacksc.png
After a shutdown even the XMS3 revert to fail safe settings. Even at 1600 MHz 9-9-9-24.
Also, there is nothing wrong with any of my RAM. All the sticks have been tested on a Gigabyte GA-990FXA-UD7 and a GA-890GPA-UD3H (using Phenom 2s though).
And also if you read what I wrote, when I got that error I never entered any RAM timings. I couldn't. I was simply trying to read them of the SPD profile as the BIOS has a function for that. And when I actually did try to change them manually after having the BIOS revert my 1866 MHz 9-10-10-28-38 settings to 800 MHz CL6 after a failed boot to Windows I couldn't, as the error message constantly popped up whenever I tried to make any changes.
There might be an FX 8150 bios incompatibility issue there along with the mem modules, you'll just have to wait for asrock's reply regarding that matter for now, phenom 2 cpu's seems to be working fine, hope someone who also uses an fx8150 with this board will shed us some light...Quote:
I've just got a mail from the support guy. He said that they are working to implement the missing memory frequency (2133, 2400) options.
Good news...thanks...:)Quote:
well one thing i do know is that this is one sexy board
wonder if it will support Noctua NH-D14 cant find nothing
about it
EDIT:
N/M i found it and no it dont support the Noctua NH-D14
i ment to say it does support Noctua NH-D14 sry i should of worded it better
but what i was trying to ask if this board would hold the Noctua NH-D14 as i didnt find
nothing about it but with alittle more searching and opening my damn eyes more i found my answer
Ty Warwian for answer my question even tho i wasnt clear on it but you knew ty again
also would you beable to show my pictures or send me a msg with pics
Thanks Roger
Anyone know when an official BIOS update with better memory handling is coming? I tried emailing Asrock with no reply? So far their support is really rocking my As:p:
Beta bios for DDR3-2133/2400.
For DDR3-2400,you need to adjust cpu voltage and cpu_nb voltage. EXP 1.4v for cpu voltage and 1.25v for cpu_nb voltage.
DOWNLOAD
Thanks a lot mate:up:Quote:
Anything new? Does anybody have the first 0.xx UEFI? (i think its the 0.27)
Thx
Just 1.5v new BIOS.
I hope that runs better than 1.3 with FX-8150 ¬¬
I test it this afternoon...
The good new are for example that you can reach 5150mhz easy, but the bad notice is that I can't stabilize the 8cores at any speed for play Battlefield 3 ¬¬
Best setup voltage/speed is 4800Mhz.
http://img683.imageshack.us/img683/2...2002133mhz.png
I think that L3 cache causes lag to Main Memory ¬¬
The new BIOS and old BIOS have a bug calculating speed from the multiplier 21x. The BIOS uses the wrong value for speed and you need to restart to get the correct value.
http://img600.imageshack.us/img600/5483/errorhj.png
I will continue investigating...
Thanks for the info, does the beta bios 1.48v has the same function as to the publicly released 1.5v bios?Quote:
1.48 has 2133/2400MHz RAM support, 1.50 does not.
1.50 bios on BD ... something it wrong ? :shocked: and i have a problem as same as comrade fasterklander .
http://image.free.in.th/z/it/111117001241.jpg
http://image.free.in.th/z/io/111117001253.jpg
http://image.free.in.th/z/iq/111117001301.jpg
http://image.free.in.th/z/ii/111117001311.jpg
I'm not sure if you have seen my posts on the previous pages but I had a bunch of similar problems with this board along with my FX-8150. The solution? I returned it to the store and bought myself a Crosshair V Formula. The result? No problems whatsoever. I just couldn't stand the horrible BIOS-support for this board, such a shame really as it seemed like a solid board hardware wise.
interesting, i followed OP 1st page post re:LLC @50%...
yeeeehaa, always left it at default, set it to 50% (1/2 in AsRock bios)...played....
went from 4.1 to 4.31gig with ease, probably more, WTF does this setting REALLY do, I have huge Vdrop under load even with 50% setting and stressing/benching, .06v, strangest thing..
wondering..
only recent thing I did was update bios to 1.5....
laterzzzz....
I'm curious why this thread all of a sudden ended on 12-1-2011?
There have obviously been new BIOS releases since then. Have all the BIOS issues been resolved? Is it now possible to run (4) DIMMs at 1866+ MHz. without issue? Has the indicated frequencies for the multipliers been corrected? Anyone have any new insight or issues with the Fatal1ty 990FX Pro mobo?
Now's your chance to speak up. I expect a lot of folks to be popping a new Vishera CPU into these boards within hours, so I'd like to know what is and what is not right on this mobo. ;)
