im currently running the EK Supreme HF under test atm with plate still fitted. Wont have full results back until it has been running at least 1 week and the block has been checked for any sign of build up. This has to be tested on a low flow pump then a high flow pump. It needs to pass both test to Get a full pass from me.
We all so have the Koolance CPU-370 which needs to go into test as well how ever all hardware is taken up atm so it will have to wait till one of the systems is freed up.
With limited hardware there is only so much we can test in one go and this will take time. How ever by testing all these blocks we can give you a good idea what it works with and what it doesn't.
I am all so to looking into a 20nm to 60nm size pearl to cover the impingement blocks how ever because of the smaller size the effect will not be as striking as the high flow blocks can achieve.
