changelog?
changelog?
A new attempt to get it right after the failure with the cancelled 1702 BIOS release.
Release Notes
[ 1801 ]
1. 2.2TB or larger HDD can be supported under RAID mode.
(Need to install IRST 10.5 version driver first, you can find it under "SATA" catalogue)
thanks to Hiker at vip.asus.forums
went to play with sabertooth and cant overclock
if i set multi to 46 blk goes to 71 lol:shakes: set to 48 it boots @ 42 n 80blk lol
its like its stuk @ 3.3
i had her @ 4.8
kid went into bios and selected oc tuner lol he was @ 4.3 on load 1.6 idle
figured it out lol i think
so board tells me i'm @ 3.3 aida64 tells me i'm @ 3.3 but cpuz tells me i'm @ 4.8 lol
guess wich proggy is right lol
1801 bios input anyone??
Sup guys cheers to all new on this thread
i got this mobo and thought the shields was made on aluminium but is plastic...
can anyone show me how u are using it ? i see that i have to put a fan in the middle but i read some of putting a 12x12 fan pointing to the cpu area and i didnt get that...
or u just removed that shield ?
thanks in advance
Sergio
i didnt use the fan slot
i put 2 60mm fans on the pwm with zipties lol
just dissable c1 c3 c6
set multi before dissabling speedstep
my board is quirky lol
but works good
thanks friend !
but u took out the black cover ? or left it ?
im building a PC for my wife so the sabert is there and if i can get a nicer 2600K i will put it there on the UD7 it boots x54 4C/8T benched 3DMV and 3DM11 hope the asus can do at least the 5Ghz stable HT i run it on my UD7
thanks bud !
Sergio
1850 Bios is out http://www.station-drivers.com/page/...ooth%20p67.htm
Not tested it, nor seen a changelog..
BIOS 1850 (Beta) released July 4, 2011
http://dlcdnet.asus.com/pub/ASUS/mb/...-ASUS-1850.zip
Beta Version
Release Notes
[ 1850 ]
Improve system stability.
ive tried google'ing the new 1850 bios and didnt come up with anything of importance. Anyone have feedback?
Guys
been a GIGABYTE fan i will test this mobo that i liked a lot
couple of questions ?
1) should i install a fan on the middle a 5x5 one for max airflow ?
2) is that plastic cover efective why plastic ? doesnt overheat ?
3) wich is a stable bios to start ?
i would like a pic of a installed fan on the mobo if not to much asking :)
cheers to all i will report how it behaves compared to my UD7
Sergio
install the 6CM fan Sergio it really helps... will have to dig for the screenshots of the thermal radar...
Hello!
Not sure if this was right spot to post but ill do it anyway! :)
I ordred this MB and dumb me a i7 2600. No K.
Its working fine, and i have OC it a bit. But there is a slight problem where the multiplier dont go up to x42 as i have in UEFI bios in windows and CPU-Z when under load. It goes to x39 and is rocksollid there. It gives a nice OC of 600, but from what i have in BIOS it should be 4.3+. aka 900 OC.
I used the auto OC function first and it set BLK to 103 and x42 turbo multiplier.
Anyone got and idea to why this happens, and it doesnt go to max multiplier underload in Windows?
There is also another part of this. I tried to set the BLK to 100 again and then try. The multiplier was then 40 of the bat in windows. And during a quick test at diffrent loads it fluxed from x39 to x41. But again not hitting x42.
I also tried only running 1 thread of test to see if it hit x42 but nothing diffrent on both BLK settings.
Ill add a pic from testing @103 and x42 in bios. Showing x39 in CPU-Z. (have gotten Realtemp btw, i know asus thing aint most accurat)
Attachment 117587
C1 on
C3 off
C6 off
Speedstep on
(have tried everything off also, but no diffrence)
Any tip or help would be much helpfull! :)
guys im testing asus i really love the BIOS and features, but im kinda lost on Load Line Calibration, wich one u use ? i tested regular and high
thanks !
Sergio
thanks zsamz
being a gigabyte fun for years now i must say i like this board a lot, love bios, uefi, and regulation, im testing my x54 chip on it with my antec 920 Khuler and it does really well, i need another LCD as im moving permantent to my lit lab lol to test it, it booted x54 perfect
cheers and thanks !
should i upgrade to latest bios ? cauz i see that it dont display CPU speed correctly on POST and inside BIOS mine brought 1502
any tip i appreciatte very much as im starting to discover new things with this board
cheers
Sergio
some pics of my quick build of the mobo
http://img812.imageshack.us/img812/7405/45476401.jpg
http://img7.imageshack.us/img7/8265/86485918.jpg
Uploaded with ImageShack.us
