Hmm, very nice board. At such low voltage 781MHz, so at reasonable 1.038-1.05V maybe board will work at ~870MHz.
Yolanda I was slightly out - its 0.975 stock - but still not bad really
http://www.mark-buckley.pwp.blueyonder.co.uk/570-A.jpg
Still nice, my reference can work at 781MHz with rather high 1.05V, because default VID is 1.038V ((
I tested the same with default 0.967V, it can work at 844MHz with 1.038V, so 8% less voltage, 8% more clock :)
Board with 0.975V, as yours, can work at 844MHz with 1.05V.
yeah seems fine - 825 and 2150 on the mem at 0.988 volts - can't grumble at that
Same card, cooler and volts as you Buckster.
In the UK it's so much cheaper than other 570s, and barely any more than an expensive 560Ti, making it a total steal.
Working mine up to around 860 core at 1.05v stable.
:) glad to hear unclean
how you finding it noise wise - its not too bad really ?
interestingly memory clocks seem to be related to the GPU core volts .... as mine wouldn't go above 2125 without artefacting at stock volts, but with a volts bump - 2200 was perfectly stable
Tested each vanila 570 individualy and they have just a 10mhz dif on core at same volts for 24/7 amazing cards
first one is cherry its 0,950 vid and does 950 easy and more second dont go above 890 but for being normal ones im very pleased
runing SLI 16/8
http://img25.imageshack.us/img25/1323/sliv.png
cheers !
Sergio
http://img46.imageshack.us/img46/538...cegtx570ne.jpg
Gigabyte GTX570 900/1800/2000 1.025V ,stable 24/7 :up:
nice :up:
EVGA GTX570 vanila 24/7 stable 950/1900/4000 @ 1.125 :up:
proof
http://img88.imageshack.us/img88/9118/captura3e.png
Uploaded with ImageShack.us
Careful with that vGPU man, or the question I will ask is how do you like your mosfets, rare, medium or well done? :D :p:
hello guys , i need help , i buy msi gtx 570 standard version , with vid 1.00V , on stock voltage i can do 800/1600/2100 , but after is problem i can't get 900mhz stable even on 1,1V for 850mhz i need 1,088V , this is :banana::banana::banana::banana: card or mayby i must unlock something ( only for games i dont use furmark or kombustor )
this is with my new batch of 2600K my second 570 dont past over 890 so i sold it and will get a SC one, my first is cherry is 0,950 vid and does 950 easy
http://img192.imageshack.us/img192/4...3c7vantage.jpg
26 k @ 4.5 gh + 570 sli @ 900/1050
http://img849.imageshack.us/img849/2479/9001050.jpg
what kinda voltage are u guys running 24/7? i have mine @ 1.05v
this chip unleash the cards on such way :D
http://img820.imageshack.us/img820/3...3c7vantage.png
***i use stock 0,950 volts for this vanila cards, no need for more on SLI they run all games at max settings
Cheers !
Sergio
@ ^ = nice, it's beats gtx 580 SLI def
GTX 580 SLI def
http://img508.imageshack.us/img508/7564/vanv.jpg
so happy i picked another vanila 570 and got the same vid as the first one 0,950 this is my first 3dm11 at 1,1 didnt try more clocks
http://img560.imageshack.us/img560/5...33c73dm111.png
cheers !!!
Sergio
@ ^ = once again, beat my gtx 580 SLI def.........................very nice score u got there
http://img198.imageshack.us/img198/6391/2011y.jpg
