I'm not sure, but I had it do it's random shut down while in the bios menu (so it's not software), and it doesn't seem to be related to CPU load, just flat shuts down with or without any load. I also tried pulling each ram stick and the sound card, but it's still doing it.
It's weird, it'll shut down then try and restart multiple times for just a second all failing until I switch off the power for a minute...then it will start back up.
I'm almost thinking it might be the motherboard (DFI X48). If it was the PSU or CPU, I would think it would struggle more when under load, but load doesn't seem to have anything to do with it. The only thing that seems to make it worse is heat, but everything looks good there, open test bench and all the chips are under water and look good. I also have extra fans blowing over the board, etc.
UPDATE: My OCZ PSU went bad, borrowing one from the kids computer while I order another...:)
