Yea I read both threads, I was just wondering on the mag3 cause it seemed to be the best pump to me for its price, and theres noth much different in it and the mcp655 and hydro L30, aside from being ac, but i can get a relay for that :).
BRING US A SHRUBBARY!!!!!
well there is infact a rather large difference, but thats another story..
suffice to say there are plenty of good reasons why the mag3 doesnt make it into my pumps guide.
We brought you the shrubbary, now can we pass??
well, would it be to much if i asked whats so bad about the mag3?
It was going to be my pump of choice but now i think im backon the market lol :)
but one thing i got off this forum was what radiator to use :)
now i too am waiting anxiously for the realease of the PA120.x, but i also read that someone ( i think it was your link ) highly recomends weapons custom heater cores.
so if it was on this forum ( i dont remember 0.o ) are his better than the PA120.x will be? cause from what I read thermochill claims to have used something a lot like heater cores ( i think ).
Yea ill post more when im home and can check up on all this instead of talking like I know something lol. :D :D
BRING US ANOTHER SHRUBBARY!
mag3 has a high failure rate and leaks if not sealed properly. some people get lucky with them, but with all of hte horror storries of these pumps I cannot reccomend them.
beyond that they have relatively high heat dump properties.
are you into max performance with no regards to noise, or quiet cooling?
well, i guess more performance cause right now im using a gigabyte heatsink that weighs about 10 pounds and you can hear it running from the other side of my house lol.
but my look on the noise is, its like a car, i love my computer to sound like a beast :) means better performance ( for the most part ).
I heard good radiators are external. Are there any internal good radiators? I hate having things outr of my case. I have a place for a 120mm fan.
Im pretty sure if it can fit in your case its fine, you just have to sacrifice the space, and i guess it depends on where you want to put it.
I think right now the favorite is the PA120.x series.
