Originally Posted by
gabe
The difference in price between our kits and these kits is huge. They are at least half the price of ours.
Therefore, if you are on a budget, if you do not mind the lower performance, or being unable to attach water-cooled VGA(s) to your loop, and if you are willing to take the chance to have to throw it away on your next CPU upgrade, then these low end kits are a target of choice for you ;) Alternatively you might also be very satisfied with a top-end heatsink , since there is relatively little difference between these kits and top-of-the-shelf heat pipes. My personal preference if I was on a budget would be to use top quality air cooling though. I see no reason to even spend another $40 or $50 over a good heatsink if I can't liquid cool my VGA's. But that's just a personal choice.
