Smarter turbo modes seems to be the theme for both companies moving fwd..
Soon the IPC of the Power Control units will become more important than that of the CPU itself :lol:
Ahhh, it's driving me nuts, I wanna know how these OCs. :D Exciting times ahead with both SB and BD released.
interesting
Is there really a worse or best case for it? When you look back at the C2 it's out of order, could do more than four instructions a clock, had crazy branch prediction, and did 128bit SSE3 instructions in a single cycle.
I think back to when the C2 launched and the only thing that looked even remotely bad was the loss of micro-op fusion in 64bit mode (which Intel got running in i7). Other than that it looked devestating and it still does. Intel have stopped making light promises since 2006.
Between sandy bridge and bulldozer I think 2011 is going to be epic.
I was just razzing Saaya a little... I honestly don't care either way. My personal guess is you will see varying results, from 0% improvements to some workloads showing as high as 20 or 25%, with an average somewhere between 10-15%. Saaya has been adamant that at best SB will only boost performance 2-3%.
On your closing thought, I absolutely concur. 2011 will be a fun year to watch the CPU race.
Without giving any range of numbers, without giving away anything ...
(I am speaking theory here, not about SandyB itself)
Benchmarks will scale based on the Amdahl's law ( http://en.wikipedia.org/wiki/Amdahl's_law ).
If some sub systems were doubled, and you use a benchmark that uses 99% of the time this subsystem, you ll see a scaling of 2X.
now, there are some specs out there for SandyB that already release publically, not very detailled, but it is there ... you know that it has AVX.
For example, if you look at linpack, it is mostly L1 cache sensitive, and Floating based ... you add on the top of this that AVX is 256 bits, and SSE4.1 is 128 ... You get some indication of the improvement ... I see a lot of speculation here, but I don't see a lot of people trying to do the math properly.
Please try to raise the debate a little, I know there are smart people reading here, I just don't see them posting the math they are asking me questions about by email ...
I am not allow to give away any performance information, just understand that for SandyB, doing the math right will help you more than using a early prototype, those are not tuned properly.
Doing the math doesn't help much unless they have more information about what improvements are build it - I don't think that all of them were already publicly disclosed yet.. Moreover, the way Turbo works on SNB is also different and it's hard to make any expectations unless that improvement (+few constants ;) τ) has been disclosed too..
Was anyone here promised 7-8Ghz runs? AVX and SSe4.1 will be useful when programs are coded to take advantage of them (not any different than using open64 can help boost opteron performance in some HPC applications). Turbo (and some IPC improvement, likely) helps single-threaded apps, and the architecture is tuned to help multi-threaded (or at least multitasking) performance and scaling. I'm not sure how an all-around performance boost makes "them" look bad. Hardware can move as fast as it wants, but at a certain point, the software has to be coded/compiled to make use of it.
My interest here lies only on SB's lowerend in a HTPC role, can any one comment on it? Think I'll just wait till IVY for the desktop part, hopefully 2011 will hit 4.5 - 5 Ghz on air :).
These chips won't be overclockable? Intel locking buses? I seem to be finding mixed evidence in my searches. You can buy a dual-core i5-680 right now and get ludicrous clock speeds and performance in all games with a cheap 1156 mobo and 4gigs of ddr3. Guess its time for the numbers waiting game.
Just one gallon?
Pft. It's worth it. I volunteer to cover the bar tab.
