Cinebench is gonna be fun on the Thuban! Already looking real good for just 3.5GHz and a 32bit OS, 7 points should be easy. :D
Please show 06 cpu score now. ;)
i think people dont realize it took a bit for the images to be uploaded to the site. i was on when you first posted and it didnt show the images just the text in the post. now finally it is showing the imags though. thanks for the updates, keep them coming.
Thanks for posting that onTOP, didn't see his images right away either. Looks like I'll get the 1055T since I can't justify the extra funds for the 1095T.
why have you posted the 3dmark start screen and not the result? :/
what can you tell us about overclocking and turbo working together?
Well from my testing
- The "Turbo" still works even you adjust the HTT up
- You can Enable / Disable it in BIOS
- If you want the "Turbo" mode work and overclock , watch for the "Max" clock
For Stock voltage / default it works fine
- CPU Usage don't require > 3 core , you will have Turbo up to ratio 200x16.5 , which is 3.3GHz
- If you got application full load > 3 core together, the Turbo won't kick in
For Overclock situation, this maybe good or bad things
The "turbo" will automatic boost up the VCore when running as "Default"
( Default VID = 1.32V , Turbo mode => Some core got 1.476V )
When I got this 1055T run at 245 x 14 ( 3430 MHz ) ,
the "Turbo" state will push the ratio to 16.5 (4042.5)
the system crashed as it's much higher clock without increasing needed Vcore :(
I haven't try changing the Clock ratio (to see if it affect the Turbo) , but surely will try to see if it affect the Turbo function
Thanks imamage for your report :up:
thanks imamage! thats kinda how i figured turbo would work. people that have their cpu clocked to its limit for 24/7 will have to keep turbo disabled
thanks for all the info. basically its identical to OCing while using CnQ. so every voltage level needs to be tested. i think this might be very worth it to adjust all the Pstates, as long as they load automatically with windows (i havnt used that program yet)
i wonder with the BE chips u can adjust the multi for P0(turbo)?
http://universitypharmacy.ca/shoponl...h_liquigel.jpg
MUST.............NOT..............BLINK !!!!!
Too much awesomeness :woot: Show us 3.8Ghz :p: But yea see if you can turn off Turbo :)
Perkam
Keep em coming imamage. thanksQuote:
AMD (161 Viewing)
Intel (126 Viewing)
Large image file warning !
LinX run @ 3.6GHz (as requested)
http://www.hkepc.com/forum/attachmen...322e3b6443.jpg
MaxxMem
http://www.hkepc.com/forum/attachmen...c4a4840a78.jpg
CineBench R11.5 @ 3.6GHz
http://www.hkepc.com/forum/attachmen...749da4103a.jpg
Cinebench R10
http://www.hkepc.com/forum/attachmen...09b243e434.jpg
Fritz Chess
http://www.hkepc.com/forum/attachmen...0f49d7ebbe.jpg
3DMark 06 CPU Test (As Request)
http://www.hkepc.com/forum/attachmen...d1326bd376.jpg
wPRIME 32M
http://www.hkepc.com/forum/attachmen...889f6ea9cd.jpg
Enjoy
I am trying to hit 4GHz w/Air now
wPrime 32M stable , but having a hard time running 3DMark 06 CPU / Cinebench bench .......
MaxxMem
Cinebench R10
Fritz Chess
wPRIME 32M
Enjoy
Thanks for the screens man, this is what we've all been waiting for! :up:
Good luck pushing for 4GHz.
lol double posted huge images ...
Nice results waiting for 4Ghz :D
Thanks for the info.
Keep it coming.
If you get a chance throw it in the M3A79-T.
Looks like the 1090T is gonna hit 4.2g easy
This is gotta p1ss0ff the guys that are under NDA. I wonder if amd will let them post sooner.
Thanks for sharing this! Can't wait to see more :)
1.536v is a little high for these things, your temps on air must be 70C unless u have a serious fan on it.
And are you also interested to run this Chess test!
http://www.xtremesystems.org/forums/...d.php?t=202139
This will give me a lot information how strong this cpu is!
more results please... ^_^
this will sell like hotcakes for sure.
