Originally Posted by
prava
Mmmm, here it is. You are only accepting the best results instead of the average (Vapor eliminates the best and the worst results, accounting them as statistical deviation), which is not good for testing purposes. Also, your test-bed is not good enough, as its pretty much rad-restricted in all senses. Of course, what one has to realize when reading Vapor's review is that in a BEST CASE SCENARIO the difference between Supreme HF and other blocks is XX, but that is because he can put out of the equation all other factors: the dissipation on his loop is hugely oversized.
You see, in your test-bench you can pretty much say that all the blocks perform the same (all data is so close you can't be sure who is on top), which means that for the same conditions as yours all of them will be equally fine. But, take in mind that Vapor's aproach is from a perspective in which the limiting factor is only the cpu block and nothing else. Yes, it is not a real life test as I don't think nobody has two triple rads + 3 pumps on its loop, but this is the only way of testing subjectively something.
