I thought I posted this earlier but the quick reply didn't go through. I haven't finished the supply/return trench yet but I did connect everything to leak test. So far so good.
I've installed the extra temperature sensor into a conduit pipe and will jam it 5-6 feet into the ground tomorrow. The grounds will still be so soft that walking on it isn't possible. I tested it this time and it's working fine with same ethernet cable. :up:
There's 1gb of pictures to dig through, so more later... I still have things to finish up and photograph.
It's kind of odd running furmark on the stock 5970 and watching the temperatures immediately jump to 13c, and then never change.
Earlier post:
The pits dug and the coils are in the ground. The final connections will have to wait until tomorrow though.
We started three hours late because of an emergency errand this morning. So I didn't finish laying, insulating, and trimming the return/supply lines. I did manage to clean out most of that little trench though. I need to head to Lowe's now to get some PVC pipe to repair a broken water pipe. :)
The ground was a quagmire so the depth varied from 3-7 feet. The highest point was at the far end where the warm water will go first, and the deepest is where the two trenches meet. Measured soil temperatures were in the low 40s Fahrenheit. My temperature probe unfortunately isn't responding. I checked it before siliconing the connections and securing it the pipe, but not after. Oh well, water in and out are all that matter anyway.
http://www.bibliognome.com/pictures/...nthetrench.jpg
http://www.bibliognome.com/pictures/theblob.jpg
