Looks like an impressive heatsink, but seriously, whats with Noctua choosing such an ugly colour scheme for their fans? They really need to ditch that ugly brown colour, it looks horrible.
I for one like it!
Normally the Megahalems or Megadhadow along with the TRUE and some others tend to perform much better @ more heat.
So having tests @ 3.8GHz and around 1.35v would be great. That is when they show their really potential and then we can see if the Noctua can stay ahead.
Itīs very common megashadow and TRUE not being the best ones @ Stock.
Regards.
The problem with Thermalright coolers is their base. They're always VERY convex, and i7 CPUs are also convex so contact is HORRIBLE unless you lap at least the heatsink.
With a properly lapped base, I'm sure the IFX14 will match or beat it.
same problem with prolimatech
http://img694.imageshack.us/img694/1017/img5503.jpg
Which brings back the old paradox of my Prolimatech on w3520.
This picture is taken right after removing the cooler, and AS5 is used.
http://img31.imageshack.us/img31/3785/picture84.th.jpg
There is a good contact on the middle, right over cores, but can I shave 2-3'C by lapping?
@ Sam_oslo:
Yes, you can.
Lapped both. And not much, no, just made sure they're perfectly flat and shiny. :p:
They weren't horrible to start with, but i just couldn't resist. :D
I think Prolimatech's claim that their HS works best non-lapped was only made because people screw up if they have no idea how it works.
On the other hand, their machining tech is fairly decent it seems, so no such huge gains comparing to True.
I think it is based on the colours of the lady on their website:
http://www.noctua.at/images/change/produkte.gifhttp://www.noctua.at/images/products...a_nh_d14_1.jpg
They should get her blue eyes in there by adding blue LEDs to the fans!
:rolleyes:
Almost 10 degrees (9.25šC) lower than the NH-U12P SE1366 @ 4GHz, here:
http://www.vortez.co.uk/contenttelle...n=file&id=1687
http://www.vortez.co.uk/contenttelle...n=file&id=1689
http://www.vortez.co.uk/contenttelle...n=file&id=1685
(Review @ VortezHardware)
Once again, Noctua delivers the beat down. :clap:
Can i use this cooler with G.Skill Trident or Dominator?
With Tridents, no. For Tridents you will need to raise the first fan:
http://www.noctua.at/images/faqs/nh_...urements_1.jpg
With Corsair Dominator, yes. You just need to remove the top heatspreader:
http://www.noctua.at/images/faqs/nh_...nator_ddr3.jpg
They have a frontal shot on their main page any one know who she is and why the fans are coloured after her?
I doubt Trident will fit, RipJaws 2GHz is generally better though and doesn't have a massive heat-spreader.
Ok guys, the work on our article has started, and it is going to take a while, since it will be a very complex test. Untill then however, my coleague poparamiro ran some quick tests, just to have an ideea about the performance of the NH-D14. I for one was stunned when I saw the results, and my poor buddy had to restest over and over again untill I could believe the results. I do not know what materials from Mars Noctua used on this one, but I never thought I would live to see this day.
i7 920, MX-2
19c temp ambient
2x800rpm - 4000mhz@1,3v - NH-D14 - 76.5c
2x800rpm - 4000mhz@1,3v - True - 80.5c
2x4000rpm - 4400mhz@1.4v - NH-D14 - 75.25c
2x4000rpm - 4400mhz@1.4v - True - 80.5c
21c temp ambient
2x800rpm - 4000mhz @1.31v - Megahalems - 79c
2x800rpm - 4000mhz @1.31v - NH-D14 - 78.25c
2x1600rpm - 4200mhz @1.41v - Megahalems - 84.25c
2x1600rpm - 4200mhz @1.41v - NH-D14 - 83.25c
http://lab501.ro/wp-content/uploads/...-NH-D14-11.JPG
Well, not surprising, is it? Beats Megahalems while being like twice bigger... I thought the difference would be more than 1c tbh.
