Originally Posted by
Xion X2
Thanks for the suggestion! The intake fan is on the bottom of the PSU (which would pose a problem since you'd be cycling warm air back through the intake,) but you could simply mount the PSU upside down to compensate.
To force warm out through the bottom would take some force, so are you thinking a hood-like fitting with maybe an exhaust fan at the bottom? That's certainly not a bad idea.
I guess the only concern I'd have with that is I had planned to pull air in through the bottom radiator, and I wouldn't want those fans cycling hot exhaust air off the PSU.
Can you imagine a PSU with a push/pull config like that, though? No temp problems there. :)
