vaow this is really amazing :slobber:
incredible!!!!!!!!!!!!!!!! amazing!!!!!!!!
memesama has WRs with Intel and AMD!!!
Barton@3613MHz
P4EE@5154MHz
:slobber: :eek:
M/B ASUS P4C800/ BIOS 1007
CPU Pentium4 XE 3.20GHz SL7AA 3339A517
CPU Cooling LN2
Memory Kingston KHX3500@CL2@256MB x2
VGA Canopus ZXR PCI
HDD IBM DTLA
Power supl â„¢FETASIS@EPR-400
Vcore 2.03V/ Vddr 3.36V/ Vio 3.72V
OS Windows Server 2003
Clock 5154.54Mhz@FSB322.16Mhz
http://members.jcom.home.ne.jp/3233730401/WS000120.JPG
cpulloverclock, I was just about to post those results :D
good timing hehhe.
Insane results there.
He also got 26sec SuperPi 1M (equal to 3.2GHz A64 FX51).
Thats pretty much the absolute performance limit for P4 EE at the moment. Even if you could push the CPU MHz a bit higher the mobos and RAM can't do much more than the 314MHz 5:4 he has already got there.
5050MHz@PI 1M = 25sQuote:
good timing hehhe.
but FX-51 is a better choice and soon FX-53 and Prescott
wcpuid detects a socket 423 = bug
:slobber:
I don't understand why they don't do 3dmark...
prescott? :rolleyes: not really...Quote:
even intel positions the prescotts under the P4EE! ;)
we'll see with some future "real" testsQuote:
lol...
P4EE @ 5gHz and 9800xt @ 600/450= 31K EASY
Here's what I don't understand...some peeps say "oh -200C is a waste, CPU's don't operate at that temp....just go -90C...it's just as good, blah, blah"
I say BS :D
C
Fugger is at 29.4k with 600/450 and 4.5Ghz i dont think he will gain over 1.5k if he's P4 where clocked 500MHz higher ;)Quote:
Originally posted by charlie
lol...
C
rather with a 9800XT@660/510 cooled by ln2Quote:
japanese guys aren't motived except holicho
You don't?? Look at my rig and Opp's... we have identical GPU clocks, but he has 160mHz more CPU and a VIA chipset..."voila! 1.3K difference"Quote:
C
u're right CHarlie he does but i dont think that if u were able to clock your cpu 130mhz higher you would gain 1.3k it just seems unrealistic. However i think that the XT is pretty much maxed out on Fugger rig, and therefore you wont see big changes in score maybe 500ish. Also remember AMD gives more point per clock than P4.Quote:
C
i tend to agree with pejsen though i think it would be real close.
i say someone volunteers to teach the jap oc'ers some english, and then have them register here on xtreme :D
That'd be AWESOME!!Quote:
Speculates:
"And today new Xtreme friends have new benchie for you..."
"I rig up LN2 container for 9800XT and EE... :D
With hard work I able to achieve 650/460 and 3D stable at 5012mHz."
31,190
translation:
Opp, put THAT in your pipe, and smoke it :D
C
december 31 there is a big big big fight between Bob Sapp and Taro Akebono (Hawaii)Quote:
That'd be AWESOME!!
Speculates:
31,190
translation:
C
KO in 30 seconds :D
It will be awesome
Akebono : "I met Bob Sapp, and he's actually a small guy.'' :banana:
http://www.asahi.com/english/sports/...0311070133.jpg
Well atleast the 3.2C I had didn't like colder cooler base than -130C or so.Quote:
I say BS
Feel free to try it yourself :D
So two people confirm this now....i'll have to try it out with my KHX, they are in 1,3 right now.Quote:
Originally posted by kromosto
and are you testing dimms at p4c800e dlx i test at my p4p800 and find dimms 2 4 is better like you too really strange isnt it :)
Wow this is pretty amazing
At first I didnt know that the sckt 423 is a bug and I remembered kennith chung :D
:D memesama is fair playQuote:
Pardon my ignorance but is that Macci and a 3.2 EE at 5.1gig?
Ok then Im convinced if it is then that the cpu here has more in her with better cooling :thumbsup:
Macci, would it be worth trying the droop mod to the asus board to see if it helps the vcore drop? I find its worse with the EE now :)
If those guys did, most others would eventually lose interest in doing 3Dmarking as the scores would be virtually unreachable.Quote:
Originally posted by Iridium192_217
:slobber:
Either that or everybody would be buying a can of LN2 with their latest computer paraphernalia.
You are my idle. Absolutely inspirational!Quote:
...Barton@3613MHz
P4EE@5154MHz...
CPU Cooling LN2
VGA Canopus ZXR PCI
HDD IBM DTLA
Clock 5154.54Mhz@FSB322.16Mhz...
creative, its memesama from Japan with the mad P4 EE clocks :)
droop mod helps with voltage drop but I personally didn't get any extra OC potential by doing it. I was just able to hit the same max MHz with lower BIOS Vcore setting.
this is getting way off topic, but oh well..
does anyone think theres a reason for him using win 2003 server? its basically just like xp pro, but is there somthing else to it.. hes used it also for his fx-51 overclock to 3ghz.
