Thanks for the detailed updates.. it's really nice to see it all in action, and the tips are helpful. Great execution on that mounting plate.
Thanks for all the kind words of support guys :)
looks amazing man! nice job on the cutting
That panel looks great bud, and a good idea to utilize that free space in the case.
Nicely done, extremely helpful tutorials.
Magnetic dish :eek: Where did you get this?
Excellent work again! Thanks also for the new tutorials. You're making great progress.
Cheers man. I just kept it slow and steady.
Thanks. I thought I'd never fit them in that small space :P
Cheers. The magnetic dish came from http://www.farnell.com
Small update:
Been trying to turn the XSPC tops round on my DDC's and have found that the hold no longer lines up with the centre of the impeller. I basically want them oriented where the outlet I facing forwards and the wire is coming out of the right hand side of the pump.
I bought some M4, 25mm machine screws as they provide a bit more "give" than the stock ones which have wide shoulders on them.
I'll let you know how I get on. :)
Amazing craftsmanship.
hoho, excellent work you're doing there!!! pretty amazing man! good job ;)
Very nice job so far...I would never have the patience for a build like this ;)
Just ordered from France. It took around one week, but as I ordered it to one of my mom's colleagues, it is in France (where the shipping costs are lower), and I can't go there (well if I really wanted, I could but that would take me 3 hours or more...). And my mom is on a trip until next wednesday, so I have to wait... :(
Guys, I got my sleeving from mdpc-x and shipping cost was only 6 euro :) It took 9 days to arrive and materials are excellent
sorry for advertising ;)
Well I got a little bit done before I head out of the country for two weeks :P
I got those XSPC tops turned round eventually by using ordianry stainless steel M screws to replace the shouldered screws that came with it. It took loads of attempts to get the damn thing lined up with the centre of the impeller though I'm reasonably sure they're fine now.
http://lh3.ggpht.com/_dctFDUOxwRw/Sp...DSC00011-6.JPG
http://lh3.ggpht.com/_dctFDUOxwRw/Sp...DSC00012-7.JPG
I also got my lovely Lian-Li radiator brackets from PPCs :D
Gonna fit these babies when I get back:
http://lh3.ggpht.com/_dctFDUOxwRw/Sp...DSC00013-4.JPG
http://lh5.ggpht.com/_dctFDUOxwRw/Sp...DSC00014-8.JPG
That's it for now :)
nice, where are you gonna fit those radiator clamps? don't really get it :D
Ah okay, I get it now :D
Yeah I also put a P/P on the front rad, just inverted the fans on the door, as the air is coming out of the case on the front.
Anyway, looks really professionnal, personnally I did all the mountings home-made :D
I have those brackets in my v2000, holding a feser 240 with scyths perfectly in the drive bays. Great product lol.
Build is looking good, keep the updates coming
w00t, update! :D
Do you know why this brackets are of different width? I have no idea why they didn't made them identical :shrug:
And also for what those hole with plastic edging is? Fan cables I guess?
I was thinking of doing that. I'm not sure though as it may screw-up the airflow inside the case. Does it work better for you?
Yeah I'm not sure either. One is adjustable whereas the other one isn't :S
The plastic edged hole is for the fan cables, yeah :)
