HWiNFO32 v3.42-615 Beta available.
Changes:
- Fixed IT8712 fan tachometer reading.
- Improved reporting of Single/Dual-channel Memory detection for K10.
- Improved SCSI device scan.
- Improved benchmark disk selection.
- Improved calculation of BCLK for Nehalem CPUs.
- Updated reporting of Tcas for Clarkdale/Arrandale.
- Improved measuring of CPU clock using HPET if available.
- Added QST 2.0 monitoring support.
- Added support of secondary LPC.
- Improved sensor monitoring for EVGA W555.
- Added VIA VN1000 chipset support.
- Added option to select driver persistance.
- Updated help file.
- Improved sensor monitoring for ASUS M2N-SLI Deluxe.
HWiNFO32 v3.43 available.
Changes:
- Improved sensor monitoring for MSI DKA790GX Platinum (MS-7550).
- Improved support of AMD 890GX and SB800/Hudson.
- Enhanced support of VIA VT8261.
- Improved sensor monitoring for ASRock series: P43DE2, P43iCafe, 770 Extreme3, 770iCafe, M3A790GXH/USB3, 880GMH/USB3, 890GMH/USB3, 890GX Extreme3.
- Improved sensor monitoring for ASUS series: M4A89GTD-PRO, M4A89GTD-PRO/USB3.
HWiNFO32 v3.43-634 Beta available.
Changes:
- Enhanced support of Sandy Bridge family.
- Added IT87xx fan divisors setup if not configured properly by default.
- Added nVidia GeForce GTX 470 and GeForce GTX 480 (GF100 / Fermi).
HWiNFO32 v3.44-650 Beta available.
Changes:
- Fixed reading from AMB.
- Improved USB scan.
- Added possibility to automatically minimalize either the Main or Sensors Window. Can be used to display only Sensor data.
- Added possibility to report sensor values in Vista Sidebar.
HWiNFO32 v3.45 Build 674
http://www.hwinfo.sk/files/hw32_345.exe
http://www.hwinfo.sk/files/hw32_345.zip
* Enhanced support of Sandy Bridge family.
* Added IT87xx fan divisors setup if not configured properly by default.
* Added nVidia GeForce GTX 470 and GeForce GTX 480 (GF100 / Fermi).
* Fixed reading from AMB.
* Improved USB scan.
* Added possibility to automatically minimalize either the Main or Sensors Window. Can be used to display only Sensor data.
* Added possibility to report sensor values in Vista Sidebar.
* Added possibility to disable particular sensor scanning.
* Added possibility to autorun HWiNFO32 during Windows start.
* Improved reporting of CPU Power for IbexPeak-based platforms.
* Several other minor updates and bugfixes.
HWiNFO32 v3.45-680 Beta
http://www.hwinfo.sk/beta/hw32_345_680.zip
Added support of Fintek F81865 LPC/Sensor.
Added Patsburg PCH support.
Added support of PCI Express 3.0 (8.0 GT/s) capabilities.
HWiNFO32 3.46 Build 693 Beta
http://www.hwinfo.sk/beta/hw32_346_693.zip
Added monitoring of sensor values in graph.
Edit:
Mumak start to post in the "news".
