Ok. so in relevance to that chart posted a few posts above are they taking the averages or are they taking the highest numbers?
If the two platform would have beend released nearly at the same time frame i still would have goen for s1366, soley for the reason that i can upgrade to gulftown.
And the reason why you don't see a higher model in my sig is, that on aircooling theres no reason to go for a higher model, thought i have a feeling that for gulftown another EE cpu might be mine. :D
thank you for proving my point that having a two different platforms is not good for the consumer and having one that allows you to install entry level up to high end is best. :)Quote:
If i could spend more money on hardware i would get a few of those puppies: :D
http://www.dell.com/content/products...555&l=en&s=biz
I'm not sure about that at all: http://www.xtremesystems.org/forums/...7&postcount=88
Anand has mixed his cinbench results before, Scientia wrote a complete article inferring the incorrect conclusion because he was comparing 32-bit to 64-bit runs, I shot him an email I will see if he can provide an explanation.
32-bit single threaded, for example, I only see +1x bump
http://forums.xcpus.com/gallery/d/96...enchR10-32.jpg
This is because windows scheduler is distributing the load across all cores (real and virtual).
Thats quite possible. But again, in the Cinebench there is a 2.5% difference. Could just be a benching/scheduler glitch. Cinebench doesnt seem to like HT in singlethreaded mode.
Yeah I hear you.It still up to AT to clarify what exactly was going on with BIOS settings on that lynnfield system.
As for i7 965,shouldn't the 920 have a bit higher Turbo boost kick compared to 965(which gets only "1" bin)?I ask since I think I read at i7 launch that 920 was to have the biggest boost from Turbo being the lowest clocked model(thus having more "headroom" than 2 higher end models,TDP wise).
No, they all have a predefined value in a linear scale. I actually think the retail 2.66Ghz got less turbomode headroom than the 2.8 and 2.93Ghz for Lynnfield. For i7 its all the same. 1x quad, 2x single/dual in C0 stepping.
All artificial limited ofcourse.
There could also be turbomode difference between C0 and D0 stepping. However I dont know and havent tested. But its worth noticing that Xeons (D0) got higher turbomode modes.
And the 920 by AT seems to be an old C0 ES sample for sure (Who knows how thats limited or not). Why dont they test with retail CPUs? :(
However its all starting to be a mess. Both from AMD and Intel.
Uncore speed differences. 200Mhz for example between AM2+ and AM3. And yet another 200Mhz between those and Opterons. Lynnfield also got a 133Mhz (I think) slower uncore than i7.
Then there is all the turbomode issue. A hot testlab could show poor results for example. Next is Hyperthreading etc.
And it certainly wont be easier in the future :p:
Yeah I know. Well this is just an earfly preview,by the time it launches hopefully there will be less unkown variables(mature boards/bios,defined models that have/don't have SMT,fixed Turbo multies etc.)
it's a good preview anyway, but given the variables, not really much point to it (tbh).
The margin of error from having poor functioning turbo mode, unknown uncore freq's etc outweigh anyones estimation of performance anyway! ( in other words, we know roughtly how it will perform given it's still nehalem, and we know dual channel DDR3 has little effect)
I agree with you Shintai, it is a mess, and a lot of reviewers unfortunatly DONT get their head around all the minor differences, and end up doing 'unfair' comparisons or incorrectly simulate other models, causing flamewards on forums :p , or accusations of reviewer brand Bias (when infact they may just have missed the detail)
the faster BCLK on the i5 affects performance does it not? or did anandtech overclock the BCLK on the i7 to 166 too and dropped the multiplier? I didn't read the review so maybe someone can fill me in >.<
