I know it sucks to put time and effort into something to not get back expected results out of it. But you really do have balls of steel. Do they clang when you run? :ROTF: Good job and thanks for the test.
I third the above... not only did you have the balls to do a cool as hell experiment, but you also had the kohonies to post honest results afterwards despite being negative results :up::up::up:
I would definitely also like to see posted results of direct die with your fuzion if you do that next. At least there you will have a "heat spreader" via copper bottom of the waterblock, plus milled channels with more surface area inside waterblock. Again be interesting to see trade off of solder heat transfer to IHS before paste/waterblock versus directly to paste/waterblock.
i just saw the results...man that was awesome! well the corei7 sure is hot thats for sure....but damn you stripped a xeon proc's ihs ...thats fearless :banana::banana::banana::banana:t :D
Pitty :(
I wonder as a thought, to salvage it, how about artic ceramique gluing some copper BGA sinks to the IHS.
Awesome project, IMO, even if it didn't turn out as well as you hoped.
:up: for this experiment man! :yepp:
Reading the quote of Cathars post I can't get the thought of 4 RD30 hammering water on that die in parallel with an 4 (3/4") to 1 (1/2") manifold. :slobber:
Great experiment. Kudos for having the balls to do this... I know mine aren't strong enough.
Would it have been possible to have mounted something to the die to increase surface area and, potentially, spread the heat?
I know what you're thinking, no, not like an IHS. Something that the water could flow on, under, and all around to improve heat transfer beyond using the IHS.
All i can say is "That is wack"...
Hey sure the temps weren't good, but it's still a success since the chip still worked and your not down $270 on a 920!:D Not all experiments are a success, hence why it's called and "experiment" and not a "sure thing"!;)
Thanks guys! Attaching something to the die like a RAM sink has it's merits. I'm going to think on this experiment a while and may get back to it one day.
I tried mounting my Fuzion to the bare die but the 1366 socket is so big that the waterblock doesn't supply enough down force to make the CPU get good contact with the socket pins. I don't have a backplate on my board and my top plate is kinda flimsy so I didn't want to force it. I needed my rig back up and running so I just swapped my old chip back in for now.
Wallwind, please note that the otherguy who did this same had waterchller in use which cooled water to 20c :)
I honestly think this would work VERY well if the channel was restricted so that high velocity water would jet across the CPU surface.
Thanks for trying something new!
fallwind it was a good try and with a more powerful pump(s) it would have had better results.
btw, I like my crow with a little garlic.
I'm certainly not disappointed. Mad props for seeing it through.
I was hoping you got better temps though. Seems the closed block will work better for you after all. :shrug:
This is the sort of Xtreme LC experiment I come here to read about. Anyone can bolt up some store bought parts, it takes courage and imagination to attempt something extraordinary.
If you're not ready to give up just yet, jamb a tube that sits just short of the die into the inflow barb and retest it.
BTW, what is that oh so shiny pump you're using?
Maybe it's because there's a dead-spot of low flow right over the surface of the die, allowing for excess heat to build up in liquid that's taking a long period of time to exit the block.
http://img291.imageshack.us/img291/9585/deadspot.png
Awesome experiment and definitely BALLS OF STEEL. Keep the faith and keep up the great work.
