0904BPMW 0243
giga 790fxt F3B bios
prime testing for more than 40min. in 4 cores :D
http://i2.photobucket.com/albums/y17...t_on_4cpus.jpg
0904BPMW 0243
How about a lower end MB and CPU? Ie. x3 710 paired with ASRock A780GXH/128M? 710's beside having locked lower multiplier are exact copies of 720BE, and A780GXH uses SB710 which already has AAC support.*
*Assuming one would hunt for 904-lucky stepping.
Got my 720B.E running all four cores. So far i'm at 3.2GHZ. Motherboard is a Gigabyte Ds4H with F2 Bios.
Batch# 0904DPCW
http://i2.photobucket.com/albums/y9/esi-slowboy/41.jpg
Anyone with 0903 GPMW proccessor succesful in unlocking thier fourth core?
finally d 4th core is primable (blend test)... :D
this time it was done on biostar 790gx3... :up:
0904bpmw
http://img338.imageshack.us/img338/2...20x4png.th.jpg
here its mine.....
X3 720 BE 0904 EPMW
http://img7.imageshack.us/img7/9843/cinebench.jpg
http://img27.imageshack.us/img27/9905/2006i.jpg
http://img7.imageshack.us/img7/765/vantagef.jpg
Here is mine for the record as well.
X3 720 BE 0904DPMW
http://img257.imageshack.us/img257/2...ryresults2.jpg
By shaolin95
manage to get it running with this speed for now....
Are all AMD tri cores (on 45nm) able to unlock the fourth core? Or just the 720BE?
You tried running them in the other channel..?
X3 720BE 0904 DPCW on Biostar 790GX
http://img441.imageshack.us/img441/627/33x3tox4.jpg
my result caczc 0903 gpmw
http://www.shrani.si/t/2I/F8/3XpGuzeo/dsc05018.jpg
http://www.shrani.si/f/3E/tv/1arNuNft/4-jedra.jpg
http://www.shrani.si/t/2C/kL/4hEqU4dr/ocx2.jpg click to enlarge
Hi!!
I have 2 Phenom II 720BE 0851FPAW and 0851FPMW... but I can't enable the 4° core with my DFI LP DK 790GX-M2RS
I'm not using the latest BIOS from the website, because I thought they would "fix" it... I have the first one that supports Phenom II.
Is there a modified BIOS, or BETA BIOS that can unlock the core??
Thanks in advance!
F3b :)
Which BETA BIOS do you have?
I've tried 02/25/2009 BETA, but my results are really bad.
R7GD225A BETA BIOS:
ACC Auto = Fail POST
ACC All Cores +2 or -2 = Fail POST
ACC Per Core 0/0/0/0 = 3 Cores visible
ACC Per Core -2/-2/-2/-2 = Fail POST
ACC Per Core +2/+2/+2/+2 = Fail POST
ACC Per Core +2/0/0/0 = Fail POST
ACC Per Core 0/+2/0/0 = Fail POST
ACC Per Core 0/0/+2/0 = Fail POST
ACC Per Core 0/0/0/+2 = Fail POST
Any other Official BIOS:
ACC Whatever = 3 Cores visible
Maybe the fourth core is really REALLY defective. Right now I'm testing with the 0851FPAW. Tomorrow I'll start testing the 0851FPMW, but I want to be sure wich BIOS I'm supposed to be trying with... because I don't know if it's my CPU or my Motherboard/BIOS.
Edit: When you turn ACC on wich model number appears on POST? Is it "Phenom X4 20"?
I have 0904 epmw, and can enable 4th core, but I cant get a temp reading... is that just something i ll have to live with, or is there a way to get it to give accurate temps?
i was able to unlock my 720. no temp sensors now. im unsure of the stepping. ill let you know once i swap out my mounting bracket on my water block
http://valid.canardpc.com/show_oc.php?id=554719
Just quick test using F3B
http://www.ukimagehost.com/uploads/dfc4fa9ad4.png
it looks like my x4 720 was short lived. i cant get my board to boot now with ACC on auto or with any ACC setting :(. it was even prime and wprme stable with all 4 cores enabled. if i could supply a copy of my bios could someone mod them?
If you go into everest in sensor you can see what your cpu temp!
http://www.ukimagehost.com/uploads/3913c87dc8.png
what would be a good board a 720be that can unlock? my biostar ta790gx A3+ doesnt play nice with ACC on Auto
my batch is caczc ac 0904fpmw
