wait u mean u haven't tried it in 32 bit yet?
If that's true it seems the issue has been fixed in Windows 7. Your 'out of range' signal is a generic message it's defaulting to - it's actually refresh rate related. Weird that it does this on a monitor, HDTV's have some different behaviour but unplayable all the same.
Did you ever try bioshock with the 1.2 patch? It fixes the refresh rate problem.
so this is waht we were saying at first ehhh?
this is a driver issue, only way to explain this kind of behaviour,
glad your getting results either way :up:
So whats wrong with just using windows 7 then? Forget vista, move on, problem solved... no?
