nice job !!! when i see your tower I wanna paint me too :)
http://wowbordeaux.free.fr/rav/atcs/IMG_2381.JPG
http://wowbordeaux.free.fr/rav/atcs/IMG_2382.JPG
I have a 360Hlabs GTX and it was difficult to install but it works
French look at you !!!
Cheers coconut :up:
Never tried to flame polish Delrin before but thought i'd give it a go and it worked :yepp:
http://www.coolercases.co.uk/atcs_840/i7_block_15.jpg
http://www.coolercases.co.uk/atcs_840/i7_block_16.jpg
http://www.coolercases.co.uk/atcs_840/i7_block_17.jpg
That turned out very well...:up: CM!
+1:up:
Very nice work coolmiester! I'm pretty sure you've mastered the art of making anything look good.
beautifull,more pictures..............
What is involved in flame polishing? Just hit it with some heat until it just barely starts to melt and thats it?
Yeah just waft a blow torch over till it becomes shiny :)
As always, thanks so much for following and the feedback left :cool:
I know a few people seem to be getting a bit confused with regard to vents and side panels with me already having the panels powder coated and the vents being white.
Just to clear that up - i found a while ago that powder coat gives a great base for paint and gets rid of all the brushed anodised finish so that's why its been powder coated already.
The vents need to be secured in place and smoothed in with car filler (bondo) but will eventually be painted all the same colour.
Anyway, vents in place and started filling and sanding which usually consists of 3 or 4 goes to get it looking completely smooth but decided to lay a coat of primer on after the first go with filler just to show how far i'm off but it is easier to see the direction of the vent now its all one colour.....even though its just in primer.
http://www.coolercases.co.uk/atcs_840/atc_62.jpg
http://www.coolercases.co.uk/atcs_840/atc_63.jpg
http://www.coolercases.co.uk/atcs_840/atc_64.jpg
http://www.coolercases.co.uk/atcs_840/atc_65.jpg
looks very very nice coolmiester, but is there not a bit more sanding needed at the top part of the vent for the blend?
LOL, you just did what i'm usually so guilty of, not reading the text :D read the above text :up:
Anyway, how cool is this???
I got to give a massive shout out to Willie at HWLabs for making me a one off GTX30 X-Flow Rad for the ATCs mod.
Over the years Willie has become a good friend and work colleague who simply put, just seems to love getting involved with my mods and this time is no exception.
He knows i tend to go for an X-Flow Rad as it makes for much easier hose routing so this time when i asked for something special he came up with the idea of having a total one off GTX which is just amazing of him to construct it for me.
As you can tell, i'm pretty happy.....and rightly so in my book as there is not many manufacturers that will go to this extent so hats off to you Wille :clap:
http://www.coolercases.co.uk/skull/hwlabs_logo.jpg
http://www.coolercases.co.uk/atcs_840/atc_hwlabs_1.jpg
http://www.coolercases.co.uk/atcs_840/atc_hwlabs_2.jpg
http://www.coolercases.co.uk/atcs_840/atc_hwlabs_3.jpg
amazing work :)
keep going ...
Wow, a one off! The HWLabs rads look exceptional, the finish is second-to-none.
I'm enjoying this mod CM, keep at it. :up:
too bad the hwlabs single pass isn't truly designed to be single pass.
WOw nice top on that cpu block! Where did you but the Delrin stock?
simple and good looking delrin top:up:
Wow, it all looks so great!
Cheers all :up:
Sorry, for keep harping on about this and i promise this is the last and i'll get onto something a bit more exciting ASAP.
Anyway, i made a matching NB block and had the blue heatsinks changed to black so looks much better imo.
OK that's it...no more!!!!
http://www.coolercases.co.uk/atcs_840/i7_block_22.jpg
I kinda liked the contrast the blue heatsinks gave the board, but I have a feeling you'll be adding some color in your typical elegant manner. :up:
Those delrin tops you made are top notch!! :clap:
What kind of clamps are you using? I hope it's evil's, those would look great on that
Pm evil-98
