Originally Posted by
Carfax
I see your point, so let me clarify.
First off, are you suggesting the HD 4870 achieves more from frequency boosts than the GTX 200?
Thats the crux of the matter. If you believe the HD 4870 gains more actual performance from raising the clockspeed than the GTX 260, then by all means, buy the HD 4870 and overclock it to the max.
I on the other hand, believe the opposite which is why I decided to go with the GTX 260.
The GTX 260 is clocked at a meager 576mhz, yet manages to easily keep up with the HD 4870 which is clocked at 750mhz.
Yes I know, cross architectural clock speed comparisons and how it relates to performance is complicated, but still, the GTX series gains a lot of performance from overclocking and is certainly not inferior to the HD 4870 in this regard.
Thats why people are calling the GTX 260 216 a GTX 280 killer, because it can easily rival, or surpass the GTX 280 when overclocked.
