sorry, what post are you referring to?
"chicken patty"
your settings of the ACC what can we do?
this is the best time i could do !
i didn`t try yet 3400 (200*17) with the 1066 strap and the ram at 4-4-4-15, but i doubt i`ll get a better result
^^^^ nice bro, how much voltage you feeding the RAM to have it a 640MHz
i gave it 2.26 if i`m not mistaken
i`d go higher with the cpu but it won`t start wind even with 1.5 at 3500
nice Pi :clap:
best ive gotten is 23.515s at 3.45ghz running at 1.57vcore.
ram timings are slowing me down...cant seem to boot over 1100mhz at cas 5 at 2.2v. this is on 2x1gb OCZ sticks....changed over to the 2x2gb HyperX sticks as Vista seems to like more memory. they have horrible timings though. at ddr8500 they run at cas 7. having better stability running at the 400mhz strap with cas 5 timings.
Attachment 87122
Prime stable at 3.3ghz at 1.475v though. software readings of 1.488v-1.504v
220fsb 15x multi 2300mhz nb 2200mhz ht 880mhz ram cas 5-6-6-18 at 2.2v
Attachment 87123
initial 3dmark06 17025
http://service.futuremark.com/compare?3dm06=8554262
3dmark vantage P13119
http://service.futuremark.com/compare?3dmv=456847
3dmark vantage X9614
http://service.futuremark.com/compare?3dmv=457303
9950be
ma-790gp-ds4h
ati 4870x2
2x2gb ddr8500 kingston hyperx
700w silverstone
ok, when i have time, tomorrow i`ll try 1.55 maybe it`ll start windows :D at over 3500 :DQuote:
hopefully i`ll have a cpu-z and super pi
working on these settings now.
Attachment 87127
boots into windows but havent had much luck completing benches.
back at it... :shrug:
Amazing work people!Keep pushing it .And remember to watch the cpu temps and temps of pwm section :)
you gave me some ideas :D
http://valid.x86-secret.com/show_oc.php?id=433594
and my beautiful super pi:D
great job guys, I havent got much time to try and do anything lately, but my CPU doesnt wanna boot at over 3.45GHz, even with the voltage between 1.5v all the way to 1.63v.
I might be getting a Q6600 soon to do some comparisons, it'll be a great to have both and compare them in benchmarks.
However i am saving some money to see if I can order a Deneb as soon as they hit the stores, that'll be sweet
so far here is my most 100% stable 24/7 setting, i'm not focusing on max clocks right now, just need to get the rig stable
still working on it
http://img374.imageshack.us/img374/4...2ghzct0.th.jpghttp://img374.imageshack.us/images/thpix.gif
My memory clock
ram : ocz 7200 sli (d9gmh) 5-5-5-15 2.4v
http://cfs7.tistory.com/original/11/.../48e8844eac9f9
^^^sweet, I can't wait till my new ram comes in. Its some Crucial Ballistics Tracers DDR2 1066, should yield a big improvement over my current memory.
Nice 24/7 setting Chicken Patty... :up:
Here's mine.... I got lower V's, Neener Neener... :D
CLICKABLE:
http://i30.photobucket.com/albums/c3...2_Everyday.jpg
That's almost an hour 4core Prime, heres a 10 pass Linpack run at the same settings:
http://i30.photobucket.com/albums/c3...02_Linpack.png
The CPU's/Chipsets have gotten much better since the early days, I'm actually pretty happy with this setting. Until Deneb comes around that is... :yepp:
My biggest problem seems to be getting my IMC speeds up. I don't know if my chip is just a little weak in that department or maybe I need to keep my HT multi and IMC multi matched....
I've noticed alot of people hitting 2.4nb are also running 2.4ht....
I've seen too many people kill their CPUs running high IMC v's, so I try not to go over 1.3 (stock). Guess that will give me something to play with tonight.. ;)
I'm waiting for that Deneb Thread though!! :up:
Yep, that's what I meant... ;)
The only reason I reference it that way is because Phenom is a little different than Intel based systems so I try to discern between the two... NB on an Intel system relates directly to the Mem Controller, while on Phenom the NB is more of an IO chip and the Mem Controller is on the CPU (IMC)...
It can get a little confusing and at least to me it provides some amount of clarity, since most Phenom bios have NBvid (IMC) and NBvolts (chipset/IO).
Chicken Patty: Hope that clears things up a little :D...
Do you run your NB(IMC)Multi at the same speed as your HTMulti?
IE: if you go into AOD does NBspeed and HTLinkSpeed show the same frequency?
I've noticed alot of people with high IMC speeds have matching HTlink speeds...
