well i said correct me if im wrong...never used ddr3 before or there dividers
I just ordered the P45T UD3P, but no clue on availability :mad:
awesome .looks like ill be ordering mine sometime next week.i hope its just as good as the ddr2 variants.also can someone recommend some good ddr3 ram?
at the 600FSB.... running at 1:1 memory clock will also be at 600 and its speed will be at DDR1200
so when running the system at 1:2, the memory clock will be 1200MHz and at speed of DDR2400.
the highest available memory multiplier in both DDR2 and DDR3 based boards are 4.0x, afaik.
the only way to get DDR2200 is to overclock the CPU FSB to 550MHz and use 4.0x memory multi.
DDR2 will never be able to run at the speed, but it's easily possible for today's DDR3 to run at that speed.
