Enzo-Tech(Dav)
Thx, Dav. But who will need to disable flash? I just can`t imagine such man :)
Enzo-Tech(Dav)
The block does look good, and its nice to know the flashing can easily be disabled. I am eager to see test results though, but take your time Martin, I know you have many irons in the fire.
I likes it :)
Couldn't you just not plug it in to disable the flash? LOL Yeah, yeah, I know, you still likey the blingy just not blinky blingy.
just got my first batch of them... :D
http://i132.photobucket.com/albums/q...ch_Luna_01.jpg
http://i132.photobucket.com/albums/q...ch_Luna_02.jpg
http://i132.photobucket.com/albums/q...ch_Luna_03.jpg
http://i132.photobucket.com/albums/q...ch_Luna_04.jpg
http://i132.photobucket.com/albums/q...ch_Luna_05.jpg
http://i132.photobucket.com/albums/q...ch_Luna_06.jpg
http://i132.photobucket.com/albums/q...ch_Luna_07.jpg
Have to say it looks even better than in those preview pics. Great finish quality as always, the "stains" you see there are not visible to me. The top cover is now metal, of the same colour as the "hold-down" plate. both come glued to the copper, just like the previous sapphire rev.a
Has you've guessed, the led can be disabled, if you don't want it on, don't conect it to a 3pin header. The rithm of the led is a quick blink twice a second +/-.
Also, 3/4" OD Compression fittings wont fit.
At first, that's what comes to mind.
Be interesting to see numbers on these...
Hey, really don't blame you. Not a fan of the amazing epileptic fit machine look.
Amazing stuff! Want to see some results!
Still no users?
i like the led's, as long as it performs well i might get one. easy enough to unplug it if i want..
If I got one of these blocks I'd put green LEDs in it. Just because I like green :p:
But I don't see how the top cover comes off.
So, who's going to do a nice comparison chart since Martin has retired from block testing?
The base design is interesting. It looks like instead of pins protruding, they're formed by depressing an area around them.
:wasntme:
Some tests of this block ??
I will buy this awesome stuff, but i need some performance results.
Sorry folks, nothing from me.
I will contact Enzo directly and see what transpires.
Cool, thanks Skinnee
Ok i have ordered this block ... soo i will check luna vs gtz :)
