4GHz wolfdale with D9GTR 1:2 P1/P2 enabled gets you about 12.9k-13.3k in last everest version.
there are OCZ PC3-16000 Flex II XLC coming to me, r00ns ramlist can tell me that are Samsung HCF0 chips. But i haven't seen any results yet.
HCF0? Huh?
Samsungs in CSX are K4B1G0846D-HCH9
There's the full list of Samsung production DDR3 IC's
http://www.samsung.com/global/busine...d=103&sht_id=1
Hmm strange, r00ns ramlist is giving me the wrong information?
http://ramlist.infinityx.nl/ddr3/
Look at the OCZ FlexxII 2000MHz's sticks.
I was talking about OCZ memory did you notice that? I want to know what kind of IC's they have.
Is a pitty that all the shops listed here are EU shipping shops only.
Anyone knows of a shop that stocks this ram and has international shipping?
you can also have a look at HCF0 here
Yes, i saw these, but they're not at Samsungs list. But price for OCZ/Corsair or A-Data Samsung HCF0 still is a lot higher that tends to think chips are more expensive too. And HCH9 isn't capable of 2GHz 8-8-8.
How did they run at the striker II Extreme? I'm going to run on a Asus P5Q3 Deluxe, so i don't hope thats also going to be a big disaster. If the OCZ memory crap out as you say i sell them and i'm going to look for something else. Maybe the CSX.
The CSX memory isn't for sale in the Netherlands is it?
I ordered a 2GB kit this morning at com-discount.de for € 117,- (+ € 20,- shipping via DHL-Premium).
The OCZ Flex II 2000's won't even run Memtest68 error-free at DDR1600 9-9-9-3X - on a Striker2Extreme that is with a stock E8500.. However the first kit worked fine before on a P5E3 Premium @ DDR2000+ but that board's a goner now, so I can't test if my OCZ's are actually faulty, or just being rejected by my S2E..
Hmm i'm going to try it and i will see if it works, I'm also going to think about the CSX's, thanks four your info
I checked the site but the 2gb version is more expensive then at comdiscount, I will check both of the sites at that time. First i'm going to try the ocz memory
Not to blame anyone, but OCZ recommends 2GHz kits with nF790i, and that's pretty normal. But if it can't work with best board in market, that isn't sign of quality. And if memory costs that much for 2GHz kit, it should be working proper. Same goes for other OCZ kits, as i'm working in big company as a service head, large numbers of OCZ memory have compatibility issues. They have excellent R&D people, so they should improve their products.
If anyone will do trip to Latvia, i can make discount for CSX kits from our shop. :D
I received my CSX DIABLO 4GB kit today... :clap::clap::clap:
I will start testing with my QX9650 and S2E when i get home.
Finally ended testing for Samsung kits. They'll be rated at 1600MHz 7-8-8 1T 1.85Vdimm with XMP of course. I'll test later at lower speeds, and maybe include 1333MHz XMP profile too, because there are still few boards that won't work at 1600MHz stable.
interesting results, 1600 cas7 1.85v is nice but what about high clocks at cas8-9, don't you checked it?
Id does 32M stable at 2GHz 8-8-8, but the reason is that at memtest it throws few errors at that speed, in windows its completely stable through dual 32M.
At 1333MHz it will be rated at 6-6-7 1.75v.
2000 cas8 32m hmmm sounds nice for the cec 1333 kits, i don't have much time to play with (but okay you are testing with 790i, not X48), but will get them back soon, and will check it asap :)
CEC 1333MHz kits are Qimonda, Samsung will be 1600MHz. I have all chipsets available to test on, even X48.
so you told me i've found of cec 1333 a 2000mhz cl9 32M stable quimonda? :D
try to get one mate, its better for compare ddr3 than 790i or else...
Retail 1333MHz kits will have Qimondas, retail 1600MHz kits will have Samsungs.
I don't need to try, because i have everything available on my desk.
