What would be cool is if you'd make some sort of a cover for you PSU cables coming out of the PSU at the bottom. Good work though!
IDLE temps at 3600mhz with 25º ambient:
http://www.pctunerup.com/up/results/...8_IDLE3600.JPG
FULL Temps at 3600mhz at 25º ambient:
http://www.pctunerup.com/up/results/...l11minutos.JPG
First 3dmark06 score:
http://www.pctunerup.com/up/results/...4248_20006.JPG
First Crysis bench Full HD 1920x1080, XP, Hight, DX9:
http://www.pctunerup.com/up/results/...ysisbench2.JPG
Thanks for comment!!
Tasty. ;)
Umm! Very nice too, just wondered if you'd tried IntelBurnTest yet?
All Pics fixed!
glad that your pics are up manyga.
finally got to take a look at how you mounted your pump.
great idea, i hope you don't mind if i borrow it. :D
the cosmos seems so tight on space with all the wc stuff in it.
haha.
Thanks biancoo!!
nice result manyga, nice how you mounted that pump... could you please share the height of the complete pump? I mean including the res ?? I want to have same res + pomp setup like you.
regards
Looks very very nice!!!
I like the all black look with the noctua's giving it some contrast.
How loud is your computer?
You said that you got your case powder coated. I was just wondering were you did. For 20 euros thats a very nice job they did there. Also how long did it take for them to powdercoat it.
( I live in belgium)
I love your build, very clean and simple (:
Can i ask you for pictures with closed side panel and UV active inside? I just want to see how much can be seen trough the side panel.
Thanks in advance! (:
WoW nice man loving the water cooling build BTW whats the thing cooling your RAM called ?
