NEW : Fast Update Feature
Now you can update major (v0.5 for example) release with minor updates (v0.51) !
A minor must be apply only on his major release ;)
It is easy ... assuming the key is E: and you are using 7-zip ... you just have to uncompress on the E: and select "replace existing file without asking" as this "french !" screenie :
http://www.nokytech.net/kodakey/wp-c...07/update1.jpg
New in this v0.51 patch:
-Maximus Extreme 1102
-Maximus II Formula 0701, 0604
-P5E64 WS Evolution 0504
-P5Q3 Deluxe 0902 , 0804, 0801
-P5Q 0901
-P5Q Deluxe 0803, 0706
-P5Q Pro 0901, 0708
-P5Q-E 0901, 0706, 0704
-Rampage Formula 0406
-Striker II Extreme 0901, 0804
-Striker 2 Formula 1401
Enjoy it ;)
You can consult all the features (MB and bios) here
