Any joy with the drivers touGe ??
Thanks for your reply, that makes a lot of sense, you know when you just get that feeling but we need to hear somebody else.
I was so close to buying an Enermax 1000w PSU today when I got a reply from Asus Tiawan telling me to use Award Bios Flash to flash the old fashioned way.
But It gets worse, I have tried to update the BIOS using awdflash version 1.33 [lastest version] but it has frozen at 50% . I have not turned off the power or reset the system, as I am awaiting instructions from Asus or any other experienaced user who can get me out of this loop without frying the BIOS CHIP with a restart mid-upgrade.
If I have to currupt the BIOS will I have to send this 3rd SIIE mobo for RMA or do you guys know a way of saving this FLASH upgrade? The thought of disconnecting my W/C loop for the 4th time is getting me down .
Any AWARD FLASH SAVING TRICKS appreciated .
A photograph of the AWARD BIOS FLASH frozen at 50%:
&*(^%$ what a predicament, sorry to hear - good luck!
never scrimp on psu - get a good psu - a beefy single 12v takes the guesswork outta figuring out what to connect to what rail on the multi rail psu's
holy crap! i'd been interested to find out if there is a solution for this problem - all you need now is a blackout
i gotta say this is one heckuv a video card once you start getting the hang of it -
it may be a pain switching modes back and forth
but 1 24" panel in sli on intel board can really rock in a deathmatch game - and thats stock clocks for sli
using hardware raid so sli with 2 cards is not an option for me
frigg what will i do if they cut out the 1 slot 2gpu configuration - go back to dating 60 year old chicks
No, I haven't tried yet. I ended up going into work a little early yesterday so didn't get around to it yet. I've got some testing to do on other things and, hopefully, get a few hours of sleep so I probably wont get around to it until later tonight.
Did you try what was suggested earlier, extract the files to your C directory before installing?
I have 2x EVGA 9800GX2's and i have no clue as to what is going on. Basically, i get the performance of slightly less than that of a Single GX2.
I have tested so much it's not even funny...
Installed and tested various different drivers ranging from 174.53 upto 174.9x, changed chipset drivers, flashed my mobo's Bios, tested each card individually and tested each PCI_E slot also. I even ran 2x PSU's just out of curiosity.....nothing nada....still performs the same.
And before anyone mentions my CPU clockspeed....i have several ppl posting results with the same clockspeed and they perform more than 14FPS AVG in the Crysis Bench @ 1900x1200 NO AA, ALL VERY HIGH DX10.
whats your 3dmark06 score !
3Dmark06 isn't really relevant to be honest as it won't show much. But here's what i get, Single Card 1 and 2 represent individual testing of a particular GX2
3Dmark06 Defaults 1280x1024
Quad SLI
SM2.0 Score: 5682
SM3.0 Score: 7853
CPU Score: 4023
Overall: 15,348
Single 9800GX2 1
SM2.0 Score: 5708
SM3.0 Score: 7370
CPU Score: 4144
Overall: 15,043
Single 9800GX2 2
SM2.0 Score: 5750
SM3.0 Score: 7353
CPU Score: 4085
Overall: 15,018
1920x1200 NO AA, 16x AF
Quad SLI
SM2.0 Score: 5392
SM3.0 Score: 7123
CPU Score: 4136
Overall: 14,525
Single 9800GX2 1
SM2.0 Score: 5475
SM3.0 Score: 6136
CPU Score: 4200
Overall: 13,726
Single 9800GX2 2
SM2.0 Score: 5475
SM3.0 Score: 6148
CPU Score: 4222
Overall: 13,753
up that q6600 to 3.5 - 3.6ghz
i wasn't too impressed with the gx2 at first but once the quad hit 3.5ghz it was playoff time, regular season was over
still seem to be driver issues but what the heck - could be worse
ey guys, hows the x64 drivers for gx2? any good driver out there? im having problem benchmarking with 174.74 vista 32bit, now im adding 2x1gb so going on 64bit Vista OS now...
which Driver should you suggest and performs well in gaming and benchmarking?
Thanks!
For those using quad sli (dual GX2) and not getting good results, this is why:
- No forceware yet natively supportss quad SLI.
- No CPU up to this date can perform on par with the GX2 thus, bottlenecking.
Even if newer forceware improves quad SLI, you'll only get a minor performance increase.
The single GX2's main purpose is so people don't have to go SLI in the first place, hence, using intel boards.
Sorry to bust your bubble :)
- Oh, try overclocking both the cards. that should get you an extra 4,000 points in 3dmark 06.
Loving mine :D
Clocks.. 750/1150/1900 on air with a 120 delta fan going like lordie at it (mods happening next week) cpu @ 5.3-5.4ghz. Check my hwbot for scores.
Quad sli won't really happen unless you push 5.4ghz+ ;)
no quad sli for me = love my hardware raid too much
single gx2's as close to sli i'm gettin
you're right u need a honkin cpu for throughput
I use Lavalyst Everest version 4.50 to monitor gpu temps. It can also monitor VRM and mem and everything else (diods, etc).
What setting do u guys use for the pre rendered frame option in the nvidia options?? Do u use the default 3 or not...
pre-rendered? what benefit is that?
Not sure !! Have a look in the nvidia control panel under the 3d options and see what you make of it..
I've gone back to 174.74
174.83 was unstable, getting the nv4 dll error.
this may not be true but ive read that 0 is a performance hit and 8 will help with performance. But xp only supports 3 or below and thats why nvidia has set it at 3. Another thing is that the higher you go with it it can start to cause lag with the mouse and movement in game. I have set mine to 0 and i cant tell any difference between that and 3. I think its more for low end cards to help with low fps but i may be wrong....
The GX2 doesn't use anything like 300W. TDP is 197W, actual power used would be less. I've clocked a GX2@780/2250 and QX@4.7Ghz quad on a 500W (34A@12v) PSU with no problems at all. A 60A PCP&C should be able to power 2 of those without any effort.
Likewise you should recalculate the cpu usage, my Q6600 used approx 200W@3.5Ghz.
http://img167.imageshack.us/img167/7...quationpg6.png
My experience thus far with my EVGA GX2.
I am running XP Pro, QX6700 3.4ghz, 1200W TTPSU, 4GB Crucial Ballistix Tracers 4-4-4-12
Latest drivers from EVGA site.
When I run Multi GPU, I get stuttering and random FPS drops.
When set to mulit display............oddly enough my FPS maintains and games run fine.
Not to pleased with not being able to set mulit GPU.
I saw mentioned in a previous post that the +12v A is something that is important and I am saying based on exp that this is very often over looked. Especially when someone goes out and buys a 700+W PSU, only to get one that hardly supports 17-22 amps, though seems like alot, actually isn't.
When looking for a PSU please take the time to double/triple check the minimum amps for the Card. It will you save you having to call in and save people headaches, frustration and aggrivation.
