How's that?:p:
well i can say my new quad is doing its work, after getting it installed and fixing the resource share to run wcg 70% of the time i have more than quadrupled my previous daily output :D
used to do ~300 avg daily now its @ ~1400 (boinc points)
Crazy!!!! :clap:
XtremeSystems 5,290,224
Only a minor 10k behind our friends :yepp:
I have 2 more Quads to put online tomorrow afternoon...so in 2 days time, we will be further in front :D
We would have done it if i did not have to send in my memory to crucial for rma. :(
I'll have a quad up soon. So hopefully it helps!
I'll have a total of 8 cores on my mini-farm. :D
i've been keeping my system on over night instead of shutting it off, for a lil over a month now i've been getting projects that take longer and my points/projects seems to have gone down a lot and i need to crunch 24/7 to keep up with what i was doing 15/7.
Damn! Only 10K away? Bahhh.
Still, I'm mighty happy with us being over 5 mill most days. Very strong, very nice!
I'm expecting a quad arriving tomorrow. Maybe. With another perhaps a few days behind it.
So that will help, some.
The cruncher I just posted in the "Pics of your Farm" thread got taken down today to redo the TRUE, and a few other things. I was getting very high temps on Core(s) 0 and 1.
So I redid the mount and this time instead of putting cardboard between the bracket and the HS I used a washer that I superglued to the bracket. I went with Shin Etsu instead of MX-2, as well. So, I'm very interested in seeing how the temps look when I get it back up in a little bit. This was my fastest machine at one point and I'd like to get it back "up there".
I also mounted an eSata bracket to the front panel, and am moving my soundcard into this rig. I took a few more pics of it and will post them in that thread.
This will be my "main rig" in the back of the house.
Onward and Upward!
Have you lapped any of the TRUE's you use? I have 2, both lapped, one has a washer glued to the bracket also. The other is the newer version and doesn't need it to be tight. But both of the them had a very rounded base. Lapping gave me about a 5 dergree drop across all cores. They are a pain to lap as holding them flat is awkward, but definitely worth it. Also, I have the Xigmatek S1283 cooler on one of my quads, and it performs real well. Just under the TRUE's performance, no need for lapping, and is $26 right now at mwave. You just need to get the bolt through kit as it come with push pins.
I'm planning to lap mine, any tips?
Take your time. If you rush you'll end up rounding things yourself.
Thanks, what's the recommended grits to go through?
I want mine to be a flat, mirror-like surface. :D
You're right, lapping a TRUE is a major pain. Hard to get a grip, hard to get even pressure across the whole surface. I did one... :)
The last three coolers I bought were Tuniq's. Two of them in their boxes, awaiting chips. I've heard the Xigmatek mentioned, just not much. Pretty good, eh? I may have to try one. That is if I ever build another rig... :rofl:
I'm kinda intrigued by the latest Noctua. Not cause I believe it can beat a TRUE, but does come somewhat close. What I'd really like to try is the version for S771. I have a real crap arrangement on one of my dual Clovers and would love to improve it.
:D
Since you asked, yes.
I use 4 grits only. I don't care for mirror finish, only flatness. http://images6.theimagehosting.com/100_2426.th.JPG So you see, 220,400,800 and 1000, along with the surface I work on.
I tape the paper down http://images6.theimagehosting.com/100_2428.ed7.th.JPG this just simplifies things so much
the thing needs lots of 220 work http://images6.theimagehosting.com/100_2429.99e.th.JPGsuper convex center and concave outer, some say figure 8 but I like back and forth, rotating the cooler 45 degrees every 15-20 strokes, hold the cooler with only enough pressure to prevent chatter or tipping
finally ready to start with 800 grit http://images6.theimagehosting.com/100_2441.th.JPG when the plating begins to disappear I make the reference lines so I can visually gauge my flatness as I progress, water on the paper becomes more important at this stage to eliminate chatter
almost ready for the 1000 http://images6.theimagehosting.com/100_2445.ecd.th.JPG so slow, now I wish I did more 220 :D by this point I am sanding only in one direction, rotating the cooler 180 degrees every 20 or so and being careful to apply even pressure
wooo hoo finally the 1000 http://images6.theimagehosting.com/100_2449.f7f.th.JPG I am pleased with this result
this is my 'polish' http://images6.theimagehosting.com/100_2450.50e.th.JPG like I mentioned, I don't care about mirror, just flat, clean and cool is ok
close enough for rock and roll http://images6.theimagehosting.com/100_2453.th.JPG :yepp:
Nice post loonym:up:
I just installed BOINC on my new quad so this will improve my numbers. Running on stock tho. Need to get two more machines up (1x 2.6 P4 & 1x 3.0 P4).
Also, is 50°c very bad for my quad while boinc is running? I have the fan throttled down as much as I can to recude any noise.
I am back up and crunching a E8400at 4.05GHz (board limiting)after some time off... I am back baby!
Next a E8500 and a Q9450
no though I just ordered a EVGA 790i Ultra and OCZ DDR3-1600 Platinum 2x1GB for testing and I am stoked about it - also a PANTONE Huey color calibrator
Something went down yesterday...
Easynews 4,458,057
XtremeSystems 4,269,494
My numbers were down around 20% too...
Everyone's numbers were down. 2CH also did a 'meager' 9M.
EDIT: That probably is because ESL is dropping in production again.
