@zucker - thanks got it!
@TonGe - that's nuts dude. You have a super board to run w/ VTT that low. My LT P35-T2R by comparison requires 1.31 V of VTT and 1.37 V of NB Vcore to run stable 8.5x400. Are you tweaking the GTL's or are they disabled?
@graysky, Not sure if it matters but the memory was @ 1233Mhz 3:4 divider when the benchmark was run.
@nemesis - got it and will be corrected in next update.
Testing a new Xeon, (speedstep active) 450 x 8 - 3600MHz
http://img.photobucket.com/albums/v3.../x264_3350.jpg
x264 HD BENCHMARK RESULTS
Please copy/paste everything below the line into the forum post to report your data
Results for x264.exe v0.58.747
encoded 1442 frames, 78.48 fps, 3904.67 kb/s
encoded 1442 frames, 79.77 fps, 3904.67 kb/s
encoded 1442 frames, 22.34 fps, 3952.97 kb/s
encoded 1442 frames, 22.30 fps, 3952.97 kb/s
encoded 1442 frames, 22.32 fps, 3952.97 kb/s
Results for x264.exe v0.59.819M
encoded 1442 frames, 87.15 fps, 3887.31 kb/s
encoded 1442 frames, 87.22 fps, 3886.93 kb/s
encoded 1442 frames, 86.98 fps, 3886.42 kb/s
encoded 1442 frames, 87.07 fps, 3889.37 kb/s
encoded 1442 frames, 25.04 fps, 3963.64 kb/s
encoded 1442 frames, 25.09 fps, 3963.20 kb/s
encoded 1442 frames, 25.04 fps, 3963.37 kb/s
encoded 1442 frames, 25.05 fps, 3962.70 kb/s
System Details
Name Intel Core 2 Quad Q9450
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz
Core Stepping C1
Technology 45 nm
Stock frequency 2666 MHz
Core Speed 3760.1 MHz (8.0 x 470.0 MHz)
FID range 6.0x - 8.0x
Northbridge Intel X38 rev. 01
Southbridge Intel 82801IR (ICH9R) rev. 02
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 15
Command Rate 2T
Memory Frequency 470.0 MHz (1:1)
Memory Type DDR2
Memory Size 3328 MBytes
Channels Dual (Symmetric)
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
max VID 1.200 V
Voltage sensor 0 1.38 Volts [0xAD] (CPU VCORE)
Number of processors 1
Number of threads 4
Number of threads 4 (max 4)
L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Package Socket 775 LGA (platform ID = 4h)
Temperature sensor 0 30°C (85°F) [0x1E] (SYSTIN)
Temperature sensor 1 42°C (107°F) [0x54] (CPUTIN)
Temperature sensor 2 2°C (34°F) [0x1FD] (AUXTIN)
Temperature sensor 0 65°C (148°F) [0x28] (core #0)
Temperature sensor 1 63°C (145°F) [0x2A] (core #1)
Temperature sensor 2 70°C (157°F) [0x23] (core #2)
Temperature sensor 3 67°C (152°F) [0x26] (core #3)
Temperature sensor 0 37°C (98°F) [0x25] (GPU Core)
got it zucker, thanks
@ghz- can you post the contents of the text file? It contains extra details such as mem timings, etc.
encoded 1442 frames, 82.98 fps, 3905.42 kb/s
encoded 1442 frames, 84.18 fps, 3905.42 kb/s
encoded 1442 frames, 83.88 fps, 3905.42 kb/s
encoded 1442 frames, 23.65 fps, 3952.85 kb/s
encoded 1442 frames, 23.66 fps, 3952.85 kb/s
encoded 1442 frames, 23.62 fps, 3952.85 kb/s
encoded 1442 frames, 23.55 fps, 3952.85 kb/s
encoded 1442 frames, 90.27 fps, 3891.45 kb/s
encoded 1442 frames, 90.01 fps, 3891.55 kb/s
encoded 1442 frames, 90.53 fps, 3891.55 kb/s
encoded 1442 frames, 90.18 fps, 3891.55 kb/s
encoded 1442 frames, 26.49 fps, 3962.72 kb/s
encoded 1442 frames, 26.54 fps, 3963.44 kb/s
encoded 1442 frames, 26.60 fps, 3963.43 kb/s
encoded 1442 frames, 26.58 fps, 3963.43 kb/s
System Details
Codename Yorkfield
Core Stepping C1
Technology 45 nm
Core Speed 3937.0 MHz (8.0 x 492.1 MHz)
Northbridge Intel G35 rev. 03
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 2T
Memory Frequency 492.1 MHz (1:1)
Memory Type DDR2
Memory Size 2048 MBytes
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition (Build 6000)
max VID 1.250 V
Voltage sensor 0 1.34 Volts [0xA8] (CPU VCORE)
Number of threads 4
Temperature sensor 0 31°C (87°F) [0x1F] (SYSTIN)
Temperature sensor 1 49°C (120°F) [0x62] (CPUTIN)
Temperature sensor 2 127°C (260°F) [0xFE] (AUXTIN)
Temperature sensor 0 64°C (147°F) [0x29] (core #0)
Temperature sensor 1 52°C (125°F) [0x35] (core #1)
Temperature sensor 2 55°C (130°F) [0x32] (core #2)
Temperature sensor 3 51°C (123°F) [0x36] (core #3)
Temperature sensor 0 57°C (134°F) [0x39] (GPU Core)
got it, thanks!
Hey graysky, got another result for you. Same rig, but with QuadChannel (4 mems) now and a little more FSB. Replace it with my old one if you like :)
encoded 1442 frames, 77.10 fps, 3904.94 kb/s
encoded 1442 frames, 79.77 fps, 3904.94 kb/s
encoded 1442 frames, 79.01 fps, 3904.94 kb/s
encoded 1442 frames, 79.08 fps, 3904.94 kb/s
encoded 1442 frames, 38.17 fps, 3974.08 kb/s
encoded 1442 frames, 38.21 fps, 3974.08 kb/s
encoded 1442 frames, 37.99 fps, 3974.08 kb/s
encoded 1442 frames, 80.11 fps, 3892.76 kb/s
encoded 1442 frames, 79.49 fps, 3893.69 kb/s
encoded 1442 frames, 79.35 fps, 3892.80 kb/s
encoded 1442 frames, 80.04 fps, 3891.22 kb/s
encoded 1442 frames, 42.73 fps, 3981.40 kb/s
encoded 1442 frames, 42.84 fps, 3981.10 kb/s
encoded 1442 frames, 42.87 fps, 3981.42 kb/s
encoded 1442 frames, 42.82 fps, 3981.46 kb/s
System Details
Name Intel Xeon E5420
Codename Harpertown
Codename Harpertown
Specification Intel(R) Xeon(R) CPU E5420 @ 2.50GHz
Core Stepping C0
Core Stepping C0
Technology 45 nm
Technology 45 nm
Stock frequency 2500 MHz
Core Speed 3292.2 MHz (7.5 x 439.0 MHz)
FID range 6.0x - 7.5x
Northbridge Intel 5400B rev. C0
Southbridge Intel 6321ESB rev. 09
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Memory Frequency 439.0 MHz (1:1)
Memory Type FB-DDR2
Memory Size 8192 MBytes
Windows Version Microsoft Windows XP x64 Professional Service Pack 2 (Build 3790)
max VID 1.213 V
max VID 1.213 V
Voltage sensor 0 1.14 Volts [0x9] (CPU VCORE)
Number of processors 2
Number of threads 8
Package Socket 771 LGA (platform ID = 6h)
Temperature sensor 0 35°C (94°F) [0x23] (SYSTIN)
Temperature sensor 1 102°C (214°F) [0x135] (CPUTIN)
Temperature sensor 2 125°C (256°F) [0xF9] (AUXTIN)
Temperature sensor 0 60°C (139°F) [0x2D] (core #0)
Temperature sensor 1 56°C (132°F) [0x31] (core #1)
Temperature sensor 2 59°C (138°F) [0x2E] (core #2)
Temperature sensor 3 60°C (139°F) [0x2D] (core #3)
Temperature sensor 0 67°C (152°F) [0x26] (core #0)
Temperature sensor 1 65°C (148°F) [0x28] (core #1)
Temperature sensor 2 61°C (141°F) [0x2C] (core #2)
Temperature sensor 3 66°C (150°F) [0x27] (core #3)
Temperature sensor 0 59°C (138°F) [0x76] (core)
Temperature sensor 0 57°C (133°F) [0x71] (core)
Temperature sensor 0 46°C (114°F) [0x5C] (core)
Temperature sensor 0 53°C (127°F) [0x6A] (core)
Cool man, got it.
encoded 1442 frames, 81.24 fps, 3905.78 kb/s
encoded 1442 frames, 82.47 fps, 3903.79 kb/s
encoded 1442 frames, 82.33 fps, 3903.79 kb/s
encoded 1442 frames, 82.69 fps, 3903.79 kb/s
encoded 1442 frames, 22.95 fps, 3953.16 kb/s
encoded 1442 frames, 22.92 fps, 3952.85 kb/s
encoded 1442 frames, 22.89 fps, 3952.85 kb/s
encoded 1442 frames, 22.84 fps, 3952.85 kb/s
encoded 1442 frames, 88.57 fps, 3888.99 kb/s
encoded 1442 frames, 88.56 fps, 3888.67 kb/s
encoded 1442 frames, 88.65 fps, 3889.34 kb/s
encoded 1442 frames, 88.65 fps, 3888.97 kb/s
encoded 1442 frames, 25.74 fps, 3962.92 kb/s
encoded 1442 frames, 25.79 fps, 3962.97 kb/s
encoded 1442 frames, 25.77 fps, 3962.75 kb/s
encoded 1442 frames, 25.81 fps, 3962.98 kb/s
System Details
Codename Yorkfield
Core Stepping C1
Technology 45 nm
Core Speed 3856.5 MHz (8.0 x 482.1 MHz)
Northbridge Intel X48 rev. 01
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 2T
Memory Frequency 482.1 MHz (1:1)
Memory Type DDR2
max VID 1.200 V
Voltage sensor 0 1.46 Volts [0xB6] (CPU VCORE)
Number of threads 4
Temperature sensor 0 32°C (89°F) [0x20] (SYSTIN)
Temperature sensor 1 48°C (118°F) [0x60] (CPUTIN)
Temperature sensor 2 6°C (42°F) [0xC] (AUXTIN)
Temperature sensor 0 70°C (157°F) [0x23] (core #0)
Temperature sensor 1 70°C (157°F) [0x23] (core #1)
Temperature sensor 2 74°C (165°F) [0x1F] (core #2)
Temperature sensor 3 71°C (159°F) [0x22] (core #3)
Looks like this benchmark test has been updated, so here are my newest results:
encoded 1442 frames, 73.83 fps, 3905.42 kb/s
encoded 1442 frames, 73.77 fps, 3905.42 kb/s
encoded 1442 frames, 73.89 fps, 3905.42 kb/s
encoded 1442 frames, 73.95 fps, 3905.42 kb/s
encoded 1442 frames, 20.35 fps, 3952.85 kb/s
encoded 1442 frames, 20.39 fps, 3952.85 kb/s
encoded 1442 frames, 20.37 fps, 3952.85 kb/s
encoded 1442 frames, 20.39 fps, 3952.84 kb/s
encoded 1442 frames, 79.55 fps, 3891.55 kb/s
encoded 1442 frames, 79.27 fps, 3889.41 kb/s
encoded 1442 frames, 79.76 fps, 3888.13 kb/s
encoded 1442 frames, 22.58 fps, 3963.43 kb/s
encoded 1442 frames, 22.74 fps, 3962.61 kb/s
encoded 1442 frames, 22.69 fps, 3963.43 kb/s
encoded 1442 frames, 22.71 fps, 3963.35 kb/s
System Details
Name Intel Core 2 Quad Q6600
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Core Stepping G0
Technology 65 nm
Stock frequency 2400 MHz
Core Speed 3600.1 MHz (9.0 x 400.0 MHz)
FID range 6.0x - 9.0x
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 2T
Memory Frequency 533.3 MHz (3:4)
Memory Type DDR2
Memory Size 8190 MBytes
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001)
max VID 1.325 V
Voltage sensor 0 1.49 Volts [0x5D] (CPU VCORE)
Number of threads 4
L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
Temperature sensor 0 39°C (102°F) [0x27] (TMPIN0)
Temperature sensor 1 52°C (125°F) [0x34] (TMPIN1)
Temperature sensor 0 66°C (150°F) [0x22] (core #0)
Temperature sensor 1 67°C (152°F) [0x21] (core #1)
Temperature sensor 2 65°C (148°F) [0x23] (core #2)
Temperature sensor 3 61°C (141°F) [0x27] (core #3)
Temperature sensor 0 45°C (112°F) [0x2D] (GPU Core)
Phenom 9850BE @ Stock 2.5Ghz. 1066 @ SPD
encoded 1442 frames, 56.36 fps, 3905.55 kb/s
encoded 1442 frames, 56.33 fps, 3905.16 kb/s
encoded 1442 frames, 56.30 fps, 3904.52 kb/s
encoded 1442 frames, 56.81 fps, 3905.01 kb/s
encoded 1442 frames, 13.44 fps, 3952.93 kb/s
encoded 1442 frames, 13.45 fps, 3952.87 kb/s
encoded 1442 frames, 13.45 fps, 3952.85 kb/s
encoded 1442 frames, 13.42 fps, 3953.11 kb/s
encoded 1442 frames, 57.20 fps, 3889.40 kb/s
encoded 1442 frames, 57.66 fps, 3889.38 kb/s
encoded 1442 frames, 57.52 fps, 3891.48 kb/s
encoded 1442 frames, 57.38 fps, 3891.47 kb/s
encoded 1442 frames, 14.41 fps, 3962.74 kb/s
encoded 1442 frames, 14.41 fps, 3962.58 kb/s
encoded 1442 frames, 14.40 fps, 3963.43 kb/s
encoded 1442 frames, 14.36 fps, 3962.84 kb/s
System Details
Name AMD Phenom X4 9850
Codename Agena
Specification AMD Phenom(tm) 9850 Quad-Core Processor
Core Stepping DR-B3
Technology 65 nm
Core Speed 2503.5 MHz (12.5 x 200.3 MHz)
Northbridge ATI RD790 rev. 00
Southbridge ATI SB600 rev. 00
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 18
Command Rate 2T
Memory Frequency 534.1 MHz (3:8)
Memory Type DDR2
Memory Size 2046 MBytes
Channels Dual (Unganged)
Voltage sensor 0 1.38 Volts [0x56] (CPU VCORE)
Number of threads 4
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Package Socket AM2+ (940)
Package Type 0x1
Temperature sensor 0 36°C (96°F) [0x24] (TMPIN0)
Temperature sensor 1 46°C (114°F) [0x2E] (TMPIN1)
Temperature sensor 2 92°C (197°F) [0x5C] (TMPIN2)
Temperature sensor 0 51°C (123°F) [0x198] (core #0)
Temperature sensor 2 51°C (123°F) [0x198] (core #2)
Temperature sensor 1 51°C (123°F) [0x198] (core #1)
Temperature sensor 3 51°C (123°F) [0x198] (core #3)
Temperature sensor 0 31°C (87°F) [0x1F] (GPU Core)
Will run on Xp SP1 in the morn
@zuker, dkx, and majord - thanks, got 'em.
encoded 1442 frames, 83.22 fps, 3904.67 kb/s
encoded 1442 frames, 83.52 fps, 3905.23 kb/s
encoded 1442 frames, 83.90 fps, 3905.23 kb/s
encoded 1442 frames, 83.14 fps, 3905.23 kb/s
encoded 1442 frames, 23.21 fps, 3952.97 kb/s
encoded 1442 frames, 23.25 fps, 3952.94 kb/s
encoded 1442 frames, 23.23 fps, 3952.94 kb/s
encoded 1442 frames, 23.20 fps, 3952.94 kb/s
encoded 1442 frames, 90.04 fps, 3889.34 kb/s
encoded 1442 frames, 90.21 fps, 3888.76 kb/s
encoded 1442 frames, 90.39 fps, 3889.12 kb/s
encoded 1442 frames, 89.95 fps, 3889.41 kb/s
encoded 1442 frames, 26.12 fps, 3962.63 kb/s
encoded 1442 frames, 26.11 fps, 3962.88 kb/s
encoded 1442 frames, 26.06 fps, 3962.77 kb/s
encoded 1442 frames, 26.10 fps, 3963.00 kb/s
System Details
Codename Yorkfield
Core Stepping C1
Technology 45 nm
Core Speed 3904.1 MHz (8.0 x 488.0 MHz)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 2T
Memory Frequency 488.0 MHz (1:1)
Memory Type DDR2
max VID 1.200 V
Voltage sensor 0 1.49 Volts [0xBA] (CPU VCORE)
Number of threads 4
Temperature sensor 1 50°C (121°F) [0x64] (CPUTIN)
Temperature sensor 2 6°C (41°F) [0xB] (AUXTIN)
Temperature sensor 0 72°C (161°F) [0x21] (core #0)
Temperature sensor 1 71°C (159°F) [0x22] (core #1)
Temperature sensor 2 75°C (166°F) [0x1E] (core #2)
Temperature sensor 3 72°C (161°F) [0x21] (core #3)
Got it man, thanks!
encoded 1442 frames, 44.28 fps, 3904.67 kb/s
encoded 1442 frames, 43.93 fps, 3904.67 kb/s
encoded 1442 frames, 44.91 fps, 3904.67 kb/s
encoded 1442 frames, 44.18 fps, 3904.67 kb/s
encoded 1442 frames, 11.18 fps, 3952.97 kb/s
encoded 1442 frames, 11.19 fps, 3952.97 kb/s
encoded 1442 frames, 44.84 fps, 3889.38 kb/s
encoded 1442 frames, 46.40 fps, 3887.98 kb/s
encoded 1442 frames, 44.95 fps, 3887.17 kb/s
encoded 1442 frames, 45.17 fps, 3889.36 kb/s
encoded 1442 frames, 11.76 fps, 3962.87 kb/s
encoded 1442 frames, 11.74 fps, 3963.64 kb/s
encoded 1442 frames, 11.73 fps, 3963.83 kb/s
encoded 1442 frames, 11.74 fps, 3962.80 kb/s
System Details
Name AMD Opteron 270 (DP)
Codename Italy
Codename Italy
Specification Dual Core AMD Opteron(tm) Processor 270
Core Stepping JH9-E6
Technology 90 nm
Technology 90 nm
Stock frequency 2000 MHz
Core Speed 2300.9 MHz (10.0 x 230.1 MHz)
Northbridge NVIDIA nForce Pro 2200 rev. A3
Southbridge NVIDIA nForce Pro 2200 rev. A3
CAS# 3.0
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 8
Command Rate 1T
Memory Frequency 230.1 MHz (CPU/10)
Memory Type DDR
Memory Size 4096 MBytes
Channels Dual
max VID 1.300 V
max VID 1.250 V
Number of threads 4
Number of threads 2 (max 2)
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
Package Socket 940
Package Socket 940
Temperature sensor 0 40°C (103°F) [0x59] (core #0)
Temperature sensor 1 42°C (107°F) [0x5B] (core #1)
Temperature sensor 0 48°C (118°F) [0x61] (core #0)
Temperature sensor 1 48°C (118°F) [0x61] (core #1)
Temperature sensor 0 52°C (125°F) [0x34] (GPU Core)
Cool man, got it. Will include in next round of updates.
encoded 1442 frames, 71.93 fps, 3905.42 kb/s
encoded 1442 frames, 71.60 fps, 3905.42 kb/s
encoded 1442 frames, 71.49 fps, 3905.42 kb/s
encoded 1442 frames, 17.32 fps, 3952.85 kb/s
encoded 1442 frames, 17.34 fps, 3952.85 kb/s
encoded 1442 frames, 17.33 fps, 3952.85 kb/s
encoded 1442 frames, 73.13 fps, 3888.65 kb/s
encoded 1442 frames, 72.78 fps, 3888.20 kb/s
encoded 1442 frames, 73.07 fps, 3887.52 kb/s
encoded 1442 frames, 72.61 fps, 3889.36 kb/s
encoded 1442 frames, 18.55 fps, 3962.64 kb/s
encoded 1442 frames, 18.57 fps, 3963.16 kb/s
encoded 1442 frames, 18.60 fps, 3963.41 kb/s
encoded 1442 frames, 18.62 fps, 3962.68 kb/s
System Details
Name AMD Phenom X4 9950 Black Edition
Codename Agena
Specification AMD Phenom(tm) 9950 Quad-Core Processor
Core Stepping DR-B3
Technology 65 nm
Core Speed 3300.3 MHz (16.5 x 200.0 MHz)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 16
Command Rate 2T
Memory Frequency 533.4 MHz (3:8)
Memory Type DDR2
Memory Size 3322 MBytes
Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600)
Voltage sensor 0 1.47 Volts [0x5C] (CPU VCORE)
Number of threads 4
Package Type 0x1
Temperature sensor 0 46°C (114°F) [0x2E] (TMPIN0)
Temperature sensor 1 39°C (102°F) [0x27] (TMPIN1)
Temperature sensor 2 71°C (159°F) [0x47] (TMPIN2)
Temperature sensor 0 49°C (120°F) [0x188] (core #0)
Temperature sensor 1 49°C (119°F) [0x184] (core #1)
Temperature sensor 3 49°C (120°F) [0x188] (core #3)
Temperature sensor 2 49°C (120°F) [0x188] (core #2)
Temperature sensor 0 66°C (150°F) [0x42] (GPU Core)
encoded 1442 frames, 80.74 fps, 3905.42 kb/s
encoded 1442 frames, 81.24 fps, 3905.42 kb/s
encoded 1442 frames, 81.10 fps, 3905.42 kb/s
encoded 1442 frames, 81.02 fps, 3905.42 kb/s
encoded 1442 frames, 22.20 fps, 3952.85 kb/s
encoded 1442 frames, 22.18 fps, 3952.85 kb/s
encoded 1442 frames, 22.05 fps, 3952.85 kb/s
encoded 1442 frames, 21.98 fps, 3952.85 kb/s
encoded 1442 frames, 87.31 fps, 3888.99 kb/s
encoded 1442 frames, 86.82 fps, 3889.35 kb/s
encoded 1442 frames, 87.56 fps, 3888.97 kb/s
encoded 1442 frames, 86.82 fps, 3889.68 kb/s
encoded 1442 frames, 24.55 fps, 3962.78 kb/s
encoded 1442 frames, 24.51 fps, 3962.44 kb/s
encoded 1442 frames, 24.56 fps, 3962.98 kb/s
encoded 1442 frames, 24.46 fps, 3962.71 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 4005.3 MHz (9.0 x 445.0 MHz)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 2T
Memory Frequency 534.0 MHz (5:6)
Memory Type DDR2
max VID 1.225 V
Voltage sensor 0 1.51 Volts [0xBD] (CPU VCORE)
Number of threads 4
Temperature sensor 0 34°C (93°F) [0x22] (SYSTIN)
Temperature sensor 2 19°C (66°F) [0x26] (AUXTIN)
Temperature sensor 1 63°C (145°F) [0x25] (core #1)
Temperature sensor 2 62°C (143°F) [0x26] (core #2)
Temperature sensor 3 67°C (152°F) [0x21] (core #3)
Temperature sensor 0 42°C (107°F) [0x2A] (GPU Core)
Stock Q9450;
encoded 1442 frames, 57.54 fps, 3905.42 kb/s
encoded 1442 frames, 58.63 fps, 3905.42 kb/s
encoded 1442 frames, 58.90 fps, 3905.42 kb/s
encoded 1442 frames, 15.97 fps, 3952.85 kb/s
encoded 1442 frames, 15.94 fps, 3952.85 kb/s
encoded 1442 frames, 64.00 fps, 3889.26 kb/s
encoded 1442 frames, 64.18 fps, 3889.04 kb/s
encoded 1442 frames, 64.13 fps, 3888.27 kb/s
encoded 1442 frames, 63.60 fps, 3886.18 kb/s
encoded 1442 frames, 18.00 fps, 3962.50 kb/s
encoded 1442 frames, 17.98 fps, 3962.63 kb/s
encoded 1442 frames, 17.95 fps, 3963.62 kb/s
encoded 1442 frames, 17.97 fps, 3963.52 kb/s
System Details
Codename Yorkfield
Core Stepping C1
Technology 45 nm
Core Speed 2669.8 MHz (8.0 x 333.7 MHz)
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IB (ICH9) rev. 02
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 12
Command Rate 2T
Memory Frequency 500.6 MHz (2:3)
Memory Type DDR2
max VID 1.250 V
Voltage sensor 0 3.36 Volts [0xD2] (+3.3V)
Number of threads 4
Temperature sensor 0 41°C (105°F) [0x29] (TMPIN0)
Temperature sensor 1 27°C (80°F) [0x1B] (TMPIN1)
Temperature sensor 0 56°C (132°F) [0x31] (core #0)
Temperature sensor 1 49°C (120°F) [0x38] (core #1)
Temperature sensor 2 51°C (123°F) [0x36] (core #2)
Temperature sensor 3 47°C (116°F) [0x3A] (core #3)
encoded 1442 frames, 63.90 fps, 3905.42 kb/s
encoded 1442 frames, 63.54 fps, 3905.42 kb/s
encoded 1442 frames, 64.09 fps, 3905.42 kb/s
encoded 1442 frames, 64.13 fps, 3905.42 kb/s
encoded 1442 frames, 17.80 fps, 3952.85 kb/s
encoded 1442 frames, 17.92 fps, 3952.85 kb/s
encoded 1442 frames, 17.82 fps, 3952.85 kb/s
encoded 1442 frames, 17.78 fps, 3952.85 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 3207.3 MHz (8.0 x 400.9 MHz)
Northbridge Intel P45 rev. A2
Southbridge Intel 82801JR (ICH10R) rev. 00
CAS# 4.0
RAS# to CAS# 4
RAS# Precharge 4
Command Rate 2T
Memory Frequency 400.9 MHz (1:1)
Memory Type DDR2
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition x64 Service Pack 1 (Build 6001)
max VID 1.300 V
Voltage sensor 0 3.23 Volts [0xCA] (+3.3V)
Number of threads 4
Temperature sensor 2 30°C (85°F) [0x1E] (TMPIN2)
Temperature sensor 0 59°C (138°F) [0x29] (core #0)
Temperature sensor 1 58°C (136°F) [0x2A] (core #1)
Temperature sensor 2 54°C (129°F) [0x2E] (core #2)
Temperature sensor 3 55°C (130°F) [0x2D] (core #3)
Temperature sensor 0 41°C (104°F) [0x28] (GPU Core)
