no it doesnt!! send it to me !
lololol
just kiddin, good luck on that (and on the whisky)
Wow, the fusion has way to much restriction for my D5 pump. I already knew that it was restrictive but, when I attempted to blow into it and notice the amount of force required to get air exit the other barb I was concerned. My concerns were verified when I installed my loop. My pump began making a noise I never heard before and that worried me. The force of the water exiting the loop into the res was far lower then normal, to low for my liking. In a nutshell if you don't find a SE I wouldn't be worried. Put a fan on the N/S bridge and call it a day IMO. Or, use all 3/8" ID tubing (I had 1/2" ID tubing).
Here are my C2D settings with 450x8 and ram at 1200mhz. Tested over night, stable. For the first post perhaps:
http://www.xtremesystems.org/forums/...postcount=4151
Added to the main post, eSp!s0. :)
I`m so proud and happy with working 400strap :bravo:
:D
I just got some trouble here.
Was about to reboot and the computer rebooted, but then it said CPU INIT.
Tried to clear cmos, put battery out for 15min.
I took the motherboard out too and checked everything.
Will try with a different cpu tomorrow...
I got this board with 4B Crucial Ballistix DDR2-800, can I start out with 3.0Ghz first and work all the way up to 3.6Ghz? I'm currently using 0602 btw. Any advices are welcome and appreciated. :)
good luck I'm testing my setup as I type this. so far I'm on 1.52V and not even stable . I'm trying to get it to 3.6ghz. I get frustrated easy so I've actually been trying for about a week now . all together about 8hrs for 3.6ghz :shakes:
I fianlly got 3.6GHz stable again on the 8 multi thanks to nuckin_futs.
Now to get bios 903 to run my setup
Anyone? Guide for 3.0Ghz?
3.0?
375 x 8... leave everything else on auto. 3GHz shouldn't be a problem at all.
1. What are your temps? If 64c scares you, you might as well stop trying to get to 3.6Ghz unless you're planning to go chilled liquid or something. A few days ago, I saw 100c on my quad when the loop kinked. So these CPUs can take a lot of heat into the high 80s.
2. Are those 4x1 rams your running capable of the speeds your pushing them? 4 sticks = plenty volts on the NB. You could try two sticks first, then 4 to eliminate that problem as a factor in your poor overclocks.
3. What are your settings?
Here is what I remember from my settings
FSB=400
Multiplier=9
FSB Strap=400
CPU Voltage=1.4-1.5 it boots up everytime but crashes occt
my temps at 1.4 are around 58-65c depending on the cpu voltage
ddr2800 is what I set it at
the voltage for the ram is set at 2.0
I can't remember what I put on the northbridge.
now for my setup, should I try the FSB strap at 400?? I am stable right now already at 4ghz (10x400) with my setup now.
look at my sig, sorry I just updated it.
I thought you had a different cpu
With 0903 bios those 0.5 multis do´nt work.
I picked/ordered this board with Ultima-90 and OCZ reaper memory (2 x 2gb). Is there enough space around the cpu socket so that the ultima-90 wont touch the memories ?
Having problems getting over 3.3 Ghz stable on my Q6600 G0.
Does 3.33Ghz at 1.3v 415*8 rock solid.
Would like to get 3.6ghz tried 400*9 and I can't seem to stabilise it. Tried all the way up to 1.4v on vcore can get in to windows but Prime95 bluesceens vista after a 5 or so loops.
Seems 3.3 is my sweetspot as the VID for my CPU is 1.3. Guess I got a duff one.
Bios 903.
Any advice?
Unless you got a bloody good CPU you'll need more than 1.4v for 3.6GHz. Stick it to 1.5v and once it passes a few hours of prime small ffts, lower it a notch (1.485v?) and try again, repeat until it becomes too unstable, bump the voltage up one notch and retest. It should now be stable.
Cheers Kup will give it a shot.
Any advice on CPuPLL? Currently using 1.5v
