MB Intelligent Tweaker (MIT)
Robust Graphics Booster...........: Auto
CPU Clock Ratio...................: 8.5
CPU Frequency.....................: 4,030
CPU Host Clock Control............: Enable
CPU Host Frequency(Mhz)...........: 475
PCI Express Frequency (Mhz).......: 105
C.I.A.2...........................: Disabled
Performance Enhance...............: Standard
System Memory Multiplier (SPD)....: 4.00B
Memory Frequency(Mhz).............: 1,900
DRAM Timing Selectable ...........: Manual
Standard Timing Control
CAS Latency Time (tCL)............: 8
DRAM RAS# to CAS# (tRCD).........: 7
DRAM RAS# Precharge (tRP).........: 6
Precharge Delay (tRAS)............: 21
Advanced Timing Control
ACT to ACT Delay(tRRD)............: 5
Rank Write to READ Delay (tWTR)...: 5
Write To Precharge Delay (tWR)....: 7
Refresh to ACT Delay (tRFC).......: 65
Read To Precharge Delay (tRTP)....: 5
Static tREAD Value (tRD)..........: 7
Static tREAD Phase Adj............: Auto
Command Rate (CMD)................: 1T
Clock Driving and Skew Control
CPU/PCIEX Clock Driving Control...: 900
CPU Clock Skew Control............: Normal
(G)MCH Clock Skew Control.........: Normal
System Voltage Control () = Base Voltages
DDR3 OverVoltage Control...(1.50v): +0.45
PCI-E OverVoltage Control.,(1.50v): Normal
FSB OverVoltage Control....(1.10v): 0.30
(G)MCH OverVoltage Control,(1.45v): 0.375
CPU GTLREF1 Voltage*.......(67%)..: Auto
CPU GTLREF2 Voltage*.......(61%)..: Normal
Loadline Calibration..............: Enabled
CPU Voltage Control...............: 1.4240v
Normal CPU Vcore..................:
Note: * Hidden Features Press [CTRL] + [F1] from main Menu to Access
Advanced Bios Features
CPU Multi-Threading...............: Enabled
Limit CPUID Max to 3..............: Disabled
No-Execute Memory Protect.........: Disabled
CPU Enhanced Halt(CIE)............: Disabled
CPU Thermal Monitor 2.............: Disabled
CPU EIST Function.................: Disabled
Virtuaalization Technology Disabled
These are the settings for 1900mhz on mt memory. I have been testing them at 2000mhz Unstabil after 6/7 hours don't know try too figuar i out
why 900 ??
(G)MCH OverVoltage Control,(1.45v): 0.375 ----> DEF VOLTAGE IS 1,25V :) TRY WITH A TESTER :)
System Memory Multiplier (SPD)....: 4.00B ---> DID U TRY 4.00D ? OR BETTER B ? D IS MORE RELAXED
CPU/PCIEX Clock Driving Control...: 900 is at 900 because if I it's stays at 800 I can't get cpu stabil.
MCH OverVoltage Control is at 1.45volt but have a fan on the Nb. 0.375
System Memory Multiplier (SPD)....: 4.00B I have find out that 4.00B is more stabil on my systems than 4.00D Don't know why just is..
I hope it helps you..
you tryed max tdr 7 fsb ?
I don't understand what you are asking. But i hope it's the write answer i give u yes i hav tryed 7 I can run it there.
aerie is reffering to, have u tryied to see whats max fsb archivable is with performance level 7
Darknezz: nice 1T timing, how in the world did you do that at 1900MHz?
I Just don't know i think that I got a very good par of memory i am only give them 1.95volts under the 2.00volt they have to run at 1800 7-7-7-20 and now i am running it at 4.00D.
It run 24/7 no problems. But i have to thank Supershanks and BenchZowner For there Help..
