I'm getting core temps much higher than my E8400 also. Not sure if the cpu is actually running hotter or this is a diode anomoly...or perhaps the thermal diode is actually working properly on the e3110, while was not with the e8400?
My e3110 temps go up as I increase the FSB, while the e8400 temps would only increase with voltage increases and seemed impervious to MHz.
I have the same batch as Eldonka Q746A535 and I have settled in at 4.0GHz with 1.31v, which has load core temps of about 55C.
