find the visontek 3870x2 flash proggies. PLease use these at your own risk...file size prevents me from uploading it here.
Ok this will flash both Bioses for the 3870x2 and will set the Clocks for both Gpu's...100%...When in 2Dmode the primary GPU will be set to half clock and in 3Dmode Both will be 100% ...Powerplay will be disabled and the Fan will still cycle as before..
Note: i suggest you use Rivatuner and set the Fan profile if you dont want the Fan going up and Down...I run 100% all the time..This is aperformance Bios and Card so im not bothered with the noise!:D
Visiontek Bios page :
You Must do Both Flashes if you Flash this! Other people have flashed other cards than VisionTek 3870x2 like the Saphire/Diamond as well..Im using this Bios with the 8.49Beta driver....If you dont run the Fan 50%+ you can heat up in 3D mode if the fan dosnt cycle up ..So i run 100%Fan!
VisionTek Bios 3870x2
http://www.visiontek.com/forum/viewt...163d91d8971935
Rivatuner 2.09
http://downloads.guru3d.com/download.php?det=163
P.S you can still use ATiGPU Tool to Overclock Both GPUs and Ram.:yepp:
Also, If you have a VisionTek 3870x2 card and Flash Goes wrong they will RMA it (Bios is Officail VisionTek PowerPlayFix)
Visiontek updates don't work for me. I get "no valid adapter found" error.
Those flashing, use the command. atiflash.exe -pa BIOSNAME.bin
The -pa will correctly flash the adapter that coresponds with correct BIOS.
Also make sure to use one of the 43 and on of the 64 kilobite BIOS files and not just two 43 or two 64.
