Originally Posted by
Daidalos
First of all thank you all for your feedback. It's nice to be able to help.
I have some new bioses for you. All bioses have 2d clocks at 300/1125 and 2d voltage at 1,214V. Low power 3d and 3d modes have voltage at 1,33 and frequencies depend on the version you choose. UVD mode is clocked at 775/1125 and has 1,3v voltage.
Also there are two bios versions. One based on the 73 bios with the normal low noise fan settings and one based on the 71 bios with the aggressive fan control for lower temps. 71 is better for those that use the stock cooler. I recommend the newer 73 to those with aftermarket coolers or those who don't like fan noise.
I have named the bios files as "core-mem-bios version.bin". So "775-1125-71.bin" means you have 3d clocks of 775 core 1125 memory and its has more aggressive fan control (based on 71 bios). I recommend to rename the file you want to flash to something like "bios1.bin" as atiflash has problems with long file names.
As always test at your own risk and feedback is welcome. :up:
