In Device Manager select you IDE/Sata cotroller
and properties and selected updriver. The select browse my computer for
driver software. Select let me pict from list. In the screen untick the
box "show compatible hardward". Scroll dowwn under the Manufactuer
column and select the Standard AHCHI driver and select next. This should
the Microsoft AHCI driver. Reboot. Then go into the bios and change your
IDE configuration to AHCI. Once your reboot you can then install the
AHCI driver for your particular motherboard.
My apologies for not noticing earlier that you wanted to use the same HDD for the Vista installation.
