Any updates on this? I still want one.
I want one also...
I'd be interested in these.
Yeah, and after all my DDC pump top testing this weekend, I have no doubt that you can increase pressure capabilities of a pump top. The D5 is a flow monster, we just need to make a top that pushes the curve to the pressure side and improves efficiency. It's all very possible...
Any new news on this? If this thing was around the $30-40 price point I'd get one for sure.
Ok, I'm too intruiged to see if I can pull it off. I'll buy the piece of delrin, mcmaster is on the same coast as me so I should be able to pick it up fairly cheap. I'll need some VERY precise measurements for initial carving and if it goes well I'll need to borrow someones pump to make 100% sure of clearances. I'll ship it to Martin for testing if he'd like to and whoever lends me their D5 will have dibs on the first production one *IF* they do go into production, at cost. I'll order the Delrin around the 8th of next month as I've got too many projects at the moment but, should be prety much cleared up by then. Any takers?
I'd buy one if it's good, I'll pay the shipping of course.
you'll pay more than shipping for a one off top.:ROTF:
DarthBeavis has dibs on either my prototype(after martin is through with it of course) or the first production top. If I'm hand milling every one of them they're not going to cost an arm and a leg but, they're not going to be cheap either. If I get enough interest in them and have them injection molded locally, they should be notably less expensive.
Of course, was meant as in "I'll pay whatever it costs as well as the shipping" ;)
It would be unheard of to expect you to give a good piece of work away for free.
Ive given up on d5's to be honest. there just too bulky. The DDC may not be as reliable, but there are so many options for it, its extremely convenient. Also the head pressure on the DDC's are excellent.
I have 2 D5's sitting not in systems anymore. 1 was sent to nol to test out on my TEC blocks, the other is sitting in a drawer. This last one was swaped out and replaced by dual ddc-3.2 which is = in foot print space.
If i had space for a D5, id rather just drop another iwaki rd-30. The Rd-30 is only a tad bit larger. If you compare to two side by side.
Regardless of all the D5 hate, Im STILL waiting for these tops. Plenty of room in my UFO for 2 of them.
Eddy can you post any pics?
Hi!
First pictures!
Results soon.
Oh! Sexy!
D5 is alive!
Very nice Eddy EK. :)
cool! :clap:
i'd like to see the D5 with that top
I want it! :yepp:
I am certainly very interested in a D5 top lke that.
will there any improvements after putting the custom top?
I made some suggestions to Eddy regarding adding mounting holes to the final version.
I suggested adding 2 threaded holes (M4) to each of the three sides of the block, like so.
It should make mounting the pump quite a bit easier - you can do anything except have the pump motor on top.
