the problem with areca cards and the X38 is the fault of intel. the card worked fine with my p35 and it works fine in other boards.
Ace,Ian:
Both you guys seem to be decent people.
Start fresh and shake hands.
Remember, friends first ok..
Yes, I do sound like your mother..
I'll say it for you.:rofl:
done!..we shaked hands in a PM.
I am embarrased by my comments which were unworthy of me. I am well aware that Ace's experienced opinion IS worth a damn and I never meant to suggest otherwise. I'm happy he has accepted my apology anyway.
Thanks for the intervention, Movieman.
I got a Adaptec 31205 pci-e x8 kontroller, and i have a LSI pcie-x4 kontroller.
Testet with my Abit x38 MB. Adaptec 31205 works in the blue pci.e 2.0 slot and the LSI works in the black pci-e 1.1 slot!!
This was the best day for me!
So on my ix38 i have 8800 ultra, LSI sas pci-e x4 and Adaptec pci-e x8 :D
And 8 Seagate 15k.5 73 gb :)
Please can someone help me!:shakes:
Which would be the better card card for the Abit IX38 where only 1 graphics card slot is being used.
AMCC 3Ware 9650SE-4LPML Serial ATA II Hardware RAID Controller Kit 4-port
or
Areca ARC-1210, 4 Port PCI-E SATAII RAID Controller
Anything else I should be considering?
Thanks.
areca released a firmware and bios update for all their cards 1.44 http://www.areca.com.tw/support/main.htm which now allows me to get into the bios on my X38.
confirm.. asus maximus extreme and areca 1210 statup BIOS entering works now
about TIME! with 1.44 firmware
I just have a couple of questions guys, I just use my system for playing games, and like them to load as fast as pssable, now I know that ram cpu ect are all factors, but do these Areca cards make much of a differance compared to say the onboard raid on most Motherboards?
I run an x38 as well and was thinking about investing in an Areca Card
The simple answer is NO, for non-parity RAID such as RAID 0 or RAID 1 (mirror). The CPU overhead that you can offload to a dedicated card only becomes an issue with parity RAID, 5 or 6, as it's calculating that parity (getting the data of a particular byte in a stripe for every disk in the RAID set, then doing an XOR or similar operation on those bytes, then writing it out to the parity stripe/disk or checking it against the previously calculated parity byte there) that is time-intensive when it's done only in software.
Check the Hardware/Storage subforum for in-depth discussion on this. But bottom line: if you are using disks that your mobo Southbridge supports in RAID and are only using RAID 0 or 1, you are better off saving the money or adding more disks to your RAID set for more speed. A RAID card would be wasted.
Could you tell me how you did it?
I flashed all 3 files using the web service to version 1.44 and I still get the BIOS not found error on boot-up. I have it plugged into the second pci 16 slot w/ no hard drives attached. I don't want to attach my hard drives until I know for sure that at boot-up my Areca BIOS is found. Any suggestions?
Just to clarify - that's the important caveat. Check compatability first around the forums, see if anyone has had problems with particular drive models on your mobo. I'm thinking of the well-known Asus P5K Premium issues here, that's my situ and I need a RAID card simply to overcome that and be sure I can attach recent disks (Samsung/WD) without problems. But I think you're using GigaByte, so you should be fine with most makes. :up:
hello
Scuse my language, i'm french.
is what some of you have activated the raid mode Intel with their card controler ?
Can you get to Intel matrix storage (CRTL+I)
