NewBeetle... did you play with DFI board's GTL+ ref volts and clk fine delay values those 2 can either allow your fsb to go higher or in worse case on bad settings prevent your system from booting even at stock cpu speeds (particularly clk fine delay it's individual memory/pcb dependent as to it's values and can change values needed depending on memory divider and timings used).
