:up: on that bracket.
On my bracket, The mounting hole distances for the pumps is 3.2" diagonally.
Mekrel,
Got a coupla' questions, hope u can help me out...
1) Could u measure the space preferably in mm as indicated by the arrows (pic1)
2) The EkREs, possible to use only 1 and add an EKREs Bottom to feed 2 pumps, any downsides...wc noob here.
TIA :up:
That distance is about 12" or 35mm.
Love the attention to detail on this project. Its gonna take a forklift to move or 3 sherpa's and an engine hoist :rofl:
I especially like that this isn't a solid black euro'd out case project. Black and Chrome.... reminds me of a musclecar. I'm wondering if your going to carry this attitude with the exterior of the case :shrug:
Looking good m8 going to keep a eye on this build :)
Ok the pump mounting holes are spades off the top and bottom ends
The diagonal cross between them (using the small rubber grommets that come with the Swiftech versions) is 3.25" or about 82.5mm. That's by eye, and isn't the easiest thing to give a visual description of because it's not a diagonal that cuts across the square cross section of the pump itself.
Might try Swiftech for a drawing.
Sorry, I avoided the question hoping someone would have a better answer, maybe with a cad drawing or something.
where do those blue wires that are hooked up to the pumps go to ,
They are rpm monitoring fan plugins.
The drawings give the inner, blind, mounting holes dimension, that I quoted, not the outer spade mount points. As everyone said, putting a ruler on the pump itself gives 3.2-3.25".
They're a sweet look on that bracket.
I figure, we're just talking amongst ourselves while waiting to see how Mekrel has tackled the psu and case top obstacles.
Has the UK mail gone back to normal?
My motherboard only has 5 pin fan connectors :(
Very nice work so far :up:
You've given me more ideas to work with. I decided to 'steal' your template for cutting the top panel for a PA120.2 - hope you don't mind :p:
Following your progress with interest.
I would like to know, how big the hole without the Panel is. Anybody an idea?
Just measured mine, and it's 348mm x 200mm
Thanks a lot! :D
nice job man.
IIRC... the internals of the ETASIS and the silverstone are the same... Unfortunalty my ETASIS psu whines randomly. Sometimes under load and sometimes not. I've learn't to live with it as i couldn't be bothered with sending it back when i got it :D
Oh? Where about's? I'm from the south of Birmingham ;)
