nice build. Lets hope you get through leak testing ok. Have you made your mind up on what to put in the other 2 bays yet where the res was ??
Just a quick update - coolant was just enough without a reservoir. The TLine is almost empty - it has about 5cm of liquid in in. This was the level after I let it run overnight. All the foam stuff has dissapeared too. When I get back from work will give shake and twist and trun the case a bit to ensure all air bubbles are out.
I think I will turn on the PC tonight if everything goes OK.
veri nic job, nice work m8
holy thread resurrection batman!:eek:
Holy %$#^#^% yeah really thread resurrection.
I was talking with a friend and was looking at this thread and noticed the reply.
Really needs an update with the new components that are running now.
I might just do that when I get a chance.
