Ediejo where do send the beer too? This is amazing as ever. I think you've an amazing tallent, eye for detial and the skills.
Lend me some of your DNA so i can pull the same off. I hope this one wins
Ediejo, very nice indeed.
but i cant seen to see the pics on the last few pages of this thread? any one else?
Love Tagan psu.
Only prob is their beautiful leads can be very hard to route around the case.
I had to use another on my latest build in a Lian Li case because I couldn't route the 8-pin motherboard lead. That dual lead just wont bend tight.
@JvT & Zytek Fan, what about a popup dvd rom in de top panel. That means it comes straight out the top. (vertical)
@Pete, you can send it to the Netherlands. ;) Then I send you some DNA from me. :up:
Nice post Pete thanks. ;)
@ginnz, there are sometimes problems with the server where I host the pictures.
@Jedda, I know the problem. Clic same psu. ;)
@CyberDruid, thanks for the compliment.
If you can pull it of, I would love to see a stealth DVD player popping up the top of the case.
Those USB, Fire wire and audio extenders you got in the top of the case will look awkward anyway, if you don't do anything about them during the modding. So moving them to another area and putting a DVD player there would a nice detail
As always, Excellent work you do. just a query, how do you remove scratches fron the plexi should you need to?
AHAHA I guess we all thought you had something planned for that. After what you did with the Carbon Li, and that amazing hidden dvd slot loader, I thought you were going to do something like that again. Just relocat the drive and custom fab an opening for it.
Was Tony at the booth? :)
You are very skilled and talented, Ediejo, my friend. :spill:
The project is shaping up nicely! :hrhr:
Any updates?
amazing work. Always a fan of your cases!
All I can say is WOW :shocked:
the perfection and work you have put into this case is amazing, I cant wait to see it finished!
Keep up the awesome work!
Ed,
Till now i've followed all your great worklogs and cases, I really think you're one of the best in here. definitely in the Netherlands! Some day I'm going to drink a beer with you :)
GROETJES VAN TWEAKERS! ;)
Update?
anything new? cant wait to see the final product, its pure art!
any updates Ediejo? we're missing your work here!
After a long time an update.
the Benelux Casemod League takes all my time. And my work the other part.
Polishing the front plate for the reservoirs.
http://ediejo.nl/Foto/ELL2/206.jpg
http://ediejo.nl/Foto/ELL2/207.jpg
http://ediejo.nl/Foto/ELL2/208.jpg
http://ediejo.nl/Foto/ELL2/209.jpg
I change to real chrome. When you hit the aluminum there is a scratch on.
Also make a start for the place for the DVD rom.
http://ediejo.nl/Foto/ELL2/210.jpg
It will come in the top of the case.
http://ediejo.nl/Foto/ELL2/211.jpg
There is still enough place for the tubes.
http://ediejo.nl/Foto/ELL2/212.jpg
The aluminum part for the psu will change for big one. That takes the whole top part. I need that so that I can make the power connector exactly above the connector on the mainbaord.
Also looking for a place for the pump. I thought it’s a good place somewhere in the middle of the case. But it will not fix with the 3 graphic cards. The line for the tubes where good in my eyes.
http://ediejo.nl/Foto/ELL2/213.jpg
So the place for the pump will be at the bottom from the case. It’s also possible to give the tubes a straight line. But the there must be come something to hold them straight. That’s for later.
http://ediejo.nl/Foto/ELL2/215.jpg
At the bottom there is also place for the hard disks. This is not the part that I will use for it. It’s only to look of it fits with the main board.
http://ediejo.nl/Foto/ELL2/216.jpg
The place is big enough. It fits with the high from the main board. Only the hard disk bay is too small. There is a big empty place behind it.
http://ediejo.nl/Foto/ELL2/217.jpg
This time no water cooled hard disks. I only use the water cooling for the 3 graphic cards.
I gone make a custom hard disk bay. Bigger than this one with place for 2 x 80 mm fans for the airflow.
http://ediejo.nl/Foto/ELL2/218.jpg
See you soon.
There are those people that when they post you smile and go right to their threads..You are one of those people.
Allways a joy to see your work.:up:
looks great
Nice update Prof;)
awesome work, as always!
well,it is a little out of hand to use an external drive if you already have such a big case like this
Woohoo! An Update!
Top notch as always.
