you are referring to CPU bus speed...the 1066 strap and 1333 strap has to do with the NB and the memory controller hub which is part of the NB...
im not sure where the DS3 awitch to 1333 strap, some boards do after 400 some a lot less , boot at 333 but increase Vcore in bios like if u were doing 450fsb understand? then use setfsb or clockgen to raise fsb in windowsQuote:
Originally Posted by burn what?
easytune sucks. anyway, i think the problem is that i can't raise the fsb without raising the memory freq. so if i boot at 266 fsb with 2xmulti on nb for 533, then raise in software, it raises the mem also, so eventually at say 400 fsb i'm at 800 on the mem, which is 1600 and out of the 1066 strap. no different than setting in bios. maybe clockgen would let me raise cpu fsb while leaving mem freq. alone. i guess that's what people are referring to when they say ds3 only runs on 1333 strap?
which choice in clockgen should i use for the ds3? i'm thinking the same as the dq6, but not sureQuote:
Originally Posted by Ajfina
Thanks. I flash this evening in DOS ...Quote:
i used the same ics setting in clockgen as the dq6 is listed. i get to slider bar in pll control, where i set a desired fsb speed, click apply and nothing happens. must be different for ds3 than for dq6. also, when i move the slider for fsb, the memory speed once again moves right with it. meaning i'm going higher into the 1333 strap. does asus have independent buses for the cpu and nb?? cause i'm no asus guy, but from what i know the fsb is the fsb, and both cpu and mem are linked to it. whether increase in bios or software it's gonna raise up outside the 1066 strap, right?? unless i'm not using clockgen correctly, in which case, what is the correct ds3 choice?. call me confused.
@burn what?: :nono:, the strap is ONLY related to BOOT (in BIOS) FSB, nothing else (i.e. dividers, multipliers, frequencies, changing frequency in Windows).
So just raise the FSB in Windows (ClockGen isn't working, are You sure? check in CPU-Z), maybe using SetFSB (personally I prefer this). And I'm not sure if this mobo is capable of 440 FSB with 1066 strap, be sure to pump some V to NB in BIOS before doing this test.
@Ajfina: really nice, on Commando I must give 2,025V (max, didn't try lower, but I can't set 510, and my CPU and RAM is capable of this FSB for sure - so it is the NB fault) and far from stock cooling to achieve 500+ @ 1066, not fully stable in any way.
man sorry if i sound like and a:banana: :banana: but mabey you should open up another thread about the gigabyte or read some that are already posted....sorry but this is going to far OT with that, its a Quad thread after all
ok, i gotcha. i'll try setfsb cause clockgen i hit apply and it thinks for a second then disappears. i really don't know the exact ds3 pll to choose so maybe that's why. i guess i can just use the gigabyte easytune then instead of clockgen or setfsb cause it does the same thing, raise fsb in software. i'll set 44412 timings, boot at stock, then raise.Quote:
Originally Posted by JMKS
i have a feeling i'm going to get mucho errors once raised above 400 fsb with 44412 timings, as the ds3 isn't good on timings at all.
:)i know, i thought about that, but i saw strap talk and took the chance to bone up on that from you guys, which i really appriciate. consider me kicked out of the thread!!:)Quote:
Originally Posted by Millyons
fyi, booting at 332 then raising to 420 in easytune=17.7 1M super pi. booting at 420 in bios = 17.89 super pi, so is a bit faster in 1066 strap, but not worth the effort on this board anyway.
that was fixed weeks ago in the 3.038 version.Quote:
OK. Has anyone discovered the volatage measure points for Vcore / Vdimm?
I only trust my Multimeter :)
anyone using Vista as an OS on the QuadGT?
That's what I want to know also. I have been wanting to test mine to find out the true voltage.Quote:
Originally Posted by Charley2020
This is the kind of thing I wanted to see. I'm pretty much at py peak with this S3 so I'm gonna get a quadGT unless something else comes along in the meantime. I'm gonna download the manual and see what features it's got. All I want before I buy it are some BIOS updates so the fsb will go past 525.Quote:
I can't find any BIOS screen shots. I'd really like to know how high vdimm and other voltages go. I want to test the full potential of my memory with this board so I need over 2.35v. I saw the latest BIOS was for feb 1. Any body using it yet? I've also heard there are RAID issues with this board, can anybody confirm this?
Originally Posted by PanteraGSTK
you know a simple search on the net would provide you with sites to look at which would provide your requested information.
here you go: http://www.anandtech.com/mb/showdoc.aspx?i=2911&p=2
today is your lucky day :)Quote:
http://img1.putfile.com/thumb/2/4118120114.jpg
http://img1.putfile.com/thumb/2/4118120149.jpg
http://img1.putfile.com/thumb/2/4118120179.jpg
http://img1.putfile.com/thumb/2/4118120028.jpg
http://img1.putfile.com/thumb/2/4118120082.jpg
No possible to flash...
I use the bios M621E_11.B02 but I have the message : binary file is not Award Bios :/
An idea ? It's because I have bios B03 ?
http://users.skynet.be/fb331210/abitbios4.jpg
I use awdflash M621E_11.B02 /py /sn /cd /cp /cc
You can read vdimm on the underside of the board from the leg of the square coil by the dimm slots in the corner..
What i am wondering is about vcore read, i dont know how to find it on the digital pwm ciruit... i just got my board in so im looking it over right now.
Edit - looking closer, it looks like there is a coil next to the otes connector by the 12v connector that will read vcore.
I also want to note that this is one of the more solid power designs i have seen yet - i am no expert, but this thing just looks quality, all really quality parts and more beefy then what i have seen on my P5B-D. I wonder why this isnt under the abit MAX brand name.
CHANGE THE (DOT)"B02" TO (DOT)"BIN" FILE OR THE APPROPRIATE FILE ASSOCIATION THAT ABIT USES FOR THE STANDARD BIOS FILES...OTHER POSSIBILITY IS (DOT)"ROM"
Originally Posted by CornerJack
abit is using the file extension .binQuote:
Originally Posted by Ace-a-Rue
Thanks for that. Have you tested RAID yet? Thats the only thing I need to see now.Quote:
thank you for your help...:)Quote:
Originally Posted by fgw
It's ICH8R, so it should be same as any other 965 boardQuote:
