Nice ;)
Did you tested multi 7 also ?
Nice ;)
btw: is 3892mhz the absolute max?
nop, i have test max screen with 11, 9, 8.5 and 8.
i can t boot with 5 and 6 multi, don t know why :(
gianni: no, it s not the max but impossible to get lower temps under chiller.
maybe its the fluid limit (-25 certified) and i ll see if i get off the ihs or not :D
get a better cooling-system :D
next week i'll go to a friend with a vapo... maybe one or two more mhz :)
@ staro
which config did you use to boot ? 11x300 and then clockgen ?
boot:Quote:
Originally Posted by stunned_guy
11*300
9*365
8.5*390
8*410
and then clockgen yes :)
That cpu controller is amazing...bootable with more than 400 mhz is great.
Try th multiplier 7 and look if it will better or not ;)
can t get into windows with x7 too :stick:
Thats not good :( You can´t go into windows with multiplier 7 and high fsb or with low fsb also ?
with high and low fsb, no boot
i had only one cpu which can boot with low multis, it was my x2 3800+
I never tried less than multiplier 7...
But your cpu ist great....can you tell me the wafer-id and batch ?
it is 1520118H60245 :)
Thx, but there is one number too much. There should only be 7 numbers before the letter ;)
edited :D
my 0631GPCW under chiller @ 1.67V cpu-temp: -2°C
http://valid.x86-secret.com/show_oc.php?id=166742
What is your batch and Wafer, gianni ?
1520118H60431
Ok now I´m on search and I think I just found it. :D
today i reached 3715mhz @ 1.74V under vapochill ls... cpu-temp ~0°C... but my validation was made with cpu-z 1.38... today the released the new 1.39.... and i couldn't validate my score... is there a posibility to validate my validation-file anyway?
Very nice Gianni! 0C BTW Your cpu is putting out some serioes heat! :cool: Oc on vapo ;)
Finaly got my Sli-Dr upp and running, did some prime tests over night, IŽll go for 3600Mhz no air if we get cold here anytime soon.... Hope it is ok to post results even if they are not Xtreme high Mhz ;)
Coling: TT Big, Ambient 20C, Hr-03 Sli on mobo.
http://i30.photobucket.com/albums/c3...ic/Prime-1.gif
Very nice!
I don't think so ... :(Quote:
Originally Posted by gianni-gt
i hate new versions :mad:
my cpu is for sale.
wanna try something esle :)
hehe how much? 1k $ :D
